8th February 2012, 09:56 AM
Fan Belt adjustment.
Hi guys,
just a quick question on where to find an adjustment screw or an adjustment to my fan belt.
belts are sqealing a bit, had a look to tighten near my alternator and cant seem locate anything...
Its gotta come of somehow??
Cheers jason
8th February 2012 09:56 AM
8th February 2012, 10:42 AM
yep forgot the important stuff.. 01 GUIII ZD30
8th February 2012, 11:37 AM
jaseb13
Hi mate, I'm pretty sure that the 3l only has a pre tensioner type adjustment. In other words if the belt is squealing it maybe worn out and the tensioner is at it's limit of travel.
I've only ever replaced one belt on mine and that was a long time ago and can't remember for sure.
The Following User Says Thank You to stock patrol For This Useful Post:
jaseb13 (10th February 2012)
9th February 2012, 11:47 AM
The ZD30 has an 'automatic' belt tensioner with a little shock absorber. It sits next to the water pump from memory.
If you have belt squeal it could be caused by the belt (worn, or stretched, or contaminated with coolant or similar), the tensioner shocker, a worn pulley bearing (or poorly aligned) or the insulators that the shocker are mounted on...
Normally with this style of belt its worth roughing up the belt with a wire brush and maybe some drilube after that. If that doesn't work it'll need to be removed and check all other items.
The Following 2 Users Say Thank You to BearGUST For This Useful Post:
gq_simon (25th October 2016), jaseb13 (10th February 2012)
10th February 2012, 11:40 AM
cheers for the info fellas was sending me a bit loopy,
after a check everything seems to be running smooth, i rubbed a bit of wax (candle) over the belt and the noise has gone so im gonna go with a worn belt. ive picked up a new one & i'll add it to the list of things to do this weekend..
