Page 2 of 33 FirstFirst 123412 ... LastLast
Results 11 to 20 of 329
Thread: Taslucas's TB42 Ti
    581 Post(s)
    Hi mate, Pirtek sell rubber reducers. Mine was a 4" to 3" reducer and I'm sure you could get 3" to 2".
    You'll to have to get a short piece of two inch pipe (metal or plastic). Slide that into the flexi pipe (clamp) and slide the other end inside the 2" side of the reducer and clamp.
    Then run a 3" pipe (metal or plastic) out the other side of the reducer (clamp) and into the elbow and (clamp).
    Below is the reducer I used for the 3" outlet on the GU air filter to the 4" stainless steel on the snorkel.
    I would try a Pirtek store for that or Purple Pig or a truck pasrts shop or something like that.
  2. The Following User Says Thank You to AB For This Useful Post:
    taslucas (7th February 2012)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Nice rig mate, sorta looks like mine just better.
    So back to the temp sender, was it second hand one the one supplied from wholesale???
  5. #13
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    yeah it was. the little plastic clips were broken, i could see wear marks where it had been attached and when the mechanic ran the ohm meter over it, it showed "open circuit". and when he replaced it, the problem went and car was fine. I have spoken to Wholesale and they are happy to refund if i post it back.
    Hello from Under Down Under!
  6. #14
    Aug 2011
    North West Tas
    56 Post(s)
    Thanks for that Andy, i will check out pirtek or the local truck place tomorrow (got the rubber elbows from the truck place)
  7. #15
    Aug 2011
    North West Tas
    56 Post(s)
    I did some checking around today, not much luck. I will use your method AB and make it up out of bits i can get lol. will get some pics as i put it together. The main problem is how to deal with the massive bolts thru the pillar! id like to get some brackets that can utilise the the same holes at the least. Will keep you posted...
  8. #16
    Aug 2011
    North West Tas
    56 Post(s)
    As i said above, i have just fitted a nomad aftermarket recalibrated valve body to my auto.
    As ive said, in the proccess of finding an auto fault i had the gear box pulled down and thouroughly inspected by Steve Watkins Automotive- Automatic transmission Specialist(i am very satisfied with the service). Upon inspecting it he found that it was in VERY good condition and recomended getting one of these valve bodies.
    Well, i have been driving it for 3 days and i highly recomend it!. It shifts so good! So lively!
    I just took the trol home the "long way" tonight (a very windy gravel track called "the Zig Zag") and the auto was amazing.
    I have attached the invoice if anyone is interested. (notice that a temp sender is included in the price, it isnt normally needed)
  9. #17
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Good stuff mate!! Must admit, now the band is adjusted, when I took mine out the other night, the changes are sharp as - no flaring etc. bloody good feeling after parting with hard earned hey??!!
    Pleased for ya mate!!
  10. The Following User Says Thank You to Bigrig For This Useful Post:
    taslucas (9th February 2012)
  11. #18
    Aug 2011
    North West Tas
    56 Post(s)
    yeah for sure! i am totally stoked!
  12. #19
    Oct 2010
    Soooo ... you gunna drive it,up from Tassie for the October meet up or what??? lol
    No, no .... seriously??
  13. #20
    Aug 2011
    North West Tas
    56 Post(s)
    would be sweet. I want to do lots of bits and pieces to it in the next few months. Who knows, i might be ready by then, but yeah it would be sweet.......
