Hi all,
Can anyone tell me what ID size hose I should buy to extend the heater hose in my 2006 TDi 4.2 Patrol.
It would make life much easier if I can purchase the hose before disconnecting the old one.
Cuppa
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
I'm looking at running the hoses along the chassis rails & up into the canopy. Easiest would be on the passenger side, but I'm uncertain of how close to the turbo is too close. Any thoughts?
Also has anyone added protection to hoses, don't want them getting 'sliced' by flying rocks. If so what did you use?
Cuppa
Reason: afterthought :-)
Why do you want to move them? I have seen a thick type of corrugated foil on hoses before not sure where you would get it from though, maybe parts shop. I wouldn't be too keen to put them anywhere near turbo. Long term heat would harden the hoses and they would crack easy.
Couldn't say for sure but I imagine probably be ok, could just shorten the life of the hoses though. I would at least carry spare hose and coolant just to be sure.
Maybe you could make some sort of a shield near the hoses?
I might do that. I bought a 4' length of silicone hose today, having learned that it's much more resistant to heat damage.
I'm a bit concerned that teeing into the coolant system before the heater might result in the cabin heater not getting as warm, or taking longer to heat up, but if it's a problem I should be able to fairly easily add a 'bypass' with a couple of 3 way ball valves, to give either the cabin heater or the hot water service priority.
Cuppa
Why not used lagged copper with a few flexi joints
Just received my 12v water solenoids today, maybe what
you need instead of using ball valves use a toggle switch
