Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Yet another Diy turbo kit td42
  1. #51
    Expert luvpsi's Avatar
    Hey mate know its been a while but how did you find the turbo so far considering it myself to turbo my n/a silver top
    GU DX Cab Chassis TD42t non intercooled, 3 inch lift, genuine steel winch bar, 33" Pro Comp All Terrains , 3"turbo back exhaust, Icom IC 400pro UHF, 12inch LED light bar, 42" light bar
    Future mods: Intercooler, more boost, dual batteries, drop links for sway bar
    Jan 2013
    97_gq_lwb mate if you can remember for the oil feed off the lhs engine mount bung what thread was it? Or if anyone else knows aswell
  4. #53
    581 Post(s)
    Quote Originally Posted by Newbiee View Post
    Pretty sure it's a 1/8 npt bud.
  5. The Following User Says Thank You to AB For This Useful Post:
    Newbiee (18th September 2013)
  6. #54
    Jan 2013
    cheers heaps for that mate!
  7. #55
    581 Post(s)
    Before you go and buy the lines make sure you can get that bung off first. Mine was seized shut and I had to go around the other side and feed off the oil sender.
    Oil won't come out, let the car settle after a drive, crc the bung, let it seep in overnight and try to get it off.
    Very easy to strip it!
    Then once off you can confirm size but I'm 99% sure it's 1/8 npt
  8. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (18th September 2013)
  9. #56
    Jan 2014
    Adelaide
    So how well did this turbo end up going and did it last long?
    Am looking at doing the same setup
  10. #57
    im the same boat as jazon wondering esp. about the performance of these china manifolds, i see them advertised all over but them being so much cheaper than other brands, one cant help wondering if its a legit product or not.
