1st February 2012, 09:43 PM
GQ Brake Pistons.. now with video
Hi Guys,
I drove home and jumped out of the Trol after hearing the brakes squeeling and the rims were so hot I could not touch them the brakes must of been draging on the discs.
I guess your not supose to pump the brake pelad when there are no pads in there as i done that and the piston poped out.Should I be able to move the piston in and out by hand ( I tried the other side one and I cant ).
If the piston is so tight how does it retract.
Is there some way to adjust the amount of drag on the disc, the Greggory manual talks of using a spring type tool to check the tension and says to adjust the drag...
Here are pics of the parts. Are they stuffed. Am I better of finding some more from a wrecker maby..
Any advice much apreciated.
Ray
1st February 2012 09:43 PM
1st February 2012, 09:49 PM
I have just put new seal kits through my callipers and the pistons took a little bit of playing around and some high temp grease but got them in by hand. Don't know anything about adjusting the drag sorry
Trollette, the angriest shorty in Victoria
The Following User Says Thank You to tusman For This Useful Post:
Trolatron (2nd February 2012)
2nd February 2012, 05:56 PM
Supacheap/repco/autobarn have a bolt in replacement unit for $50. (for a GQ)
I have located a bloke in cairns selling them for $22 each. at this price, it is not worth the $20 for the rebuild kit.
The Following User Says Thank You to werafa For This Useful Post:
2nd February 2012, 08:11 PM
tusman
Thanks mate, I will have to get some of that high temp grease too.
Theres no way mine were going back in easly .
2nd February 2012, 08:24 PM
werafa
I phoned Nissan and they wanted $125 for seal kit both sides, and $154 per piston.
Repco was $18 per side for seal kit and they said pistons wrer not listed at all...
Might take them into local brake joint and see what they say.
Will go into Super cheap too.
Cheers Ray
PS. see what happens I might hit you up for more details on the pistons Werafa.
2nd February 2012, 08:42 PM
no worries,
will be doing them in the next two weeks with a bit of luck. this week is the control arm bushes
2nd February 2012, 09:35 PM
RIP - valued member and true gentleman of this forum that will be missed by many!
the usual grease for brake components used to be rubber grease. I've never used HT grease on rubber brake components.
"As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
3rd February 2012, 02:42 AM
mate it looks like you have simply melted the caliper seal to the piston.
try soaking the piston in gasket stripper or something, thinners take ya pick.
just remember to be sure it's totaly clean of anything once cleaned up.
use rubber grease only going back in.
FYI, your not supposed to use anything but rubber grease and brake fluid to be technical you be the judge.
Reason: more
3rd February 2012, 02:45 AM
werafa
what is the replacement bolt in unit, your talking about
3rd February 2012, 06:34 PM
Robo
Thats probably right to mate as the rim caliper and even the tyre were incredibly hot. Any ideas what caused them to get hot.
