Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
Thread: How to fit a Pertronix Electronic Ignition system to your GQ TB42
  1. #71
    Quote Originally Posted by liftlid View Post
    Is there a vendor on the forum that sells these?
    hey gary, how did you go with it mate? i couldnt get it off anyone on the forum i ended up going a random site.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Haven't got one yet
  4. #73
    Jun 2014
    I still have some questions on this old thread!
    I picked up a dizzy with the igniter 2 (hall effect) from the scrappy. Looks ok and I want to do a straight swap with the original dizzy. I'm assuming I can leave original coil and ballast resistor with all wires still intact - right?
    If all is well I will buy the flamethrower coil next. In that case I need to remove ballast resistor and tape up the 2 wires - right?
  5. #74
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yep spot on mate. You can retain the original coil as it is only "recommended" to upgrade the coil. Then later you can put the flame thrower is as you've described.
    >>>tappin from tassie
    Hello from Under Down Under!
  6. The Following User Says Thank You to taslucas For This Useful Post:
    amm009uk (1st August 2016)
  7. #75
    Aug 2011
    North West Tas
    56 Post(s)
    Keep an eye on your tacho as any problems with the pertronix or coil will show up as a flickering tacho needle.
    >>>tappin from tassie
  8. The Following User Says Thank You to taslucas For This Useful Post:
  9. #76
    Expert ripper's Avatar
    Leeton NSW
    Quote Originally Posted by amm009uk View Post
    I bought a Flamethrower and couldn't make it work. Got a mechanic to tune it after that and he said throw the new one away and keep using the original Bosch one. He reckons they're the only ones worth having.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  10. The Following User Says Thank You to ripper For This Useful Post:
  11. #77
    Aug 2011
    North West Tas
    56 Post(s)
    My flamethrower has been installed and working for years now. You can damage them though. A mate with the same set up did the old 180 out trick and hurt his flame thrower coil so that it would miss but only under load.
    >>>tappin from tassie
  12. The Following User Says Thank You to taslucas For This Useful Post:
  13. #78
    Jun 2014
    Thanks guys much appreciated
  14. #79
    Jul 2021
    sorry to drag up an old thread. I have installed a pertronix Hall effect and now I want to install a gt40 coil and bypass the ballast resistor.
    Im just wondering what cables go where on the coil from the resistor?
    I have attached a picture of my old coil.
  15. The Following User Says Thank You to Callum87 For This Useful Post:
    MB (7th July 2021)
  16. #80
    472 Post(s)
    Probably no help mate but back in a similar vintage petroleum pimping FJ40/45 days found fancy red gt40 coils problematic in the cold IIRC and reverted back to OEM + bog stock resistors…unsure memory
