Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 80
Thread: How to fit a Pertronix Electronic Ignition system to your GQ TB42
    spring ridge
    Hey rusty just wondering if you had thought about using another coil like they surguest or are you happy with the standard nissian coil?
    Quote Originally Posted by spring_ridge_guy View Post
    hey mate, just noticed your post, i did think about it, but at the moment im happy with the increase in fuel economy, i can honestly say that dramatic is an understatement. also the car revs better and has MUCH more low down pull than before. its amazing that somthing so simple could change all that. maybe in the future ill change it but its not a priority atm as its not hurting anything leaving the old coil on there and to buy the new one would just be hurting my pocket =)
    cheers
    nic
  4. #13
    So these things are really that good? I've been tossing up whether to get one or not but if they're that good for the economy then I'm all for it. Which one is best, Lobe Sensing or Hall Effect?
    Cheers, Chris.
  5. #14
    Quote Originally Posted by KRISTOFFA View Post
    Cheers, Chris.
    i use the lobe sensing job and to be honest the install couldnt be easier (see earlier in the thread) the think the downfall of the other on is that if the unit fails (which it shouldnt but you can never be too careful) you cant just put your old points back on which will get you outta trouble. also, yeah i think they are that good. from full to dead empty i was getting 300ks dead on every time but now im pushing wayyy closer to 400. that is a pretty good increase, especially when you do all the math for $130 that i paid it would put me infront after 5 or six tanks...
  6. #15
    That seems pretty easily justifiable. I do pretty big kms every week so any way to save fuel is a good thing.
  7. #16
    Expert ripper's Avatar
    Leeton NSW
    I did mine a while back, and yeah, dead easy if you had clear instructions. As it was I fiddled around for a fair while, mostly because I made the mistake of changing the coil at the same time, and it turned out that the new coil was faulty. Put the old coil back in and it's all good now.
    Edit: Just thought it might be worth adding a warning about not leaving the ignition turned on without the engine running. I read that this will cause the module to overheat and burn out fairly quickly.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  8. #17
    Quote Originally Posted by ripper View Post
    thanks mate, i did not know that! i will definately look into it, thats kind of a worry.
  9. #18
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    nice job. top writeup and pics..
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  10. #19
    Hardcore
    central coast nsw
    You work for XXXX . lol.
    Great thread and pics.
    link for group buy pertronic ver II "variable dwell" $165 each unit
    http://www.nissanpatrol.com.au/forum...c-II-for-tb42s
  11. #20
    Jul 2011
    Narellan NSW
    Hi mate i just got one of the Pertronix Electronic Ignition. It says something about a Ballast Resistor and one wire going to the 12 volt side of the resistor. Is that how you have your set up?
    As in your pic's you have it wired up to the coil only.
