30th January 2012, 10:56 PM
The Following 9 Users Say Thank You to BJNSW For This Useful Post:
bazman (6th May 2023), Darian (3rd February 2012), Gecko17 (10th March 2014), jff45 (3rd June 2012), Paul Tkalec (9th March 2014), rottodiver (31st January 2012), Thirsty (2nd February 2012), twisty (31st January 2012), YNOT (31st January 2012)
30th January 2012 10:56 PM
31st January 2012, 07:18 AM
Thanks BJNSW, I'd never heard of these before now.
Tony
31st January 2012, 11:20 AM
G'day BJNSW, thanks for the info. So about 15% hp increase with the DFAS ($250 + fit and tune), nice. But the fuel economy improvement has sold me.
GU1 Auto ST4500 lpg/petrol.
31st January 2012, 04:05 PM
whoa, that sound good. I've already got a K&N air filter, Pacemaker extractors and tiapan exaust. Which Im all happy about the change. I am about to modify the head cylinder, only because I've blown a head gasket. So may as well do something since its off. I will have to look into the DFAS.
1st February 2012, 06:16 PM
Fantastic. I'm having similar issues with my 4.5L and am just about to get my first dyno. Lots of great ideas to try.
Poor performance from the 4.5L Nissans seems to be a common story, but you've given me hope taht I can get an improvement with the right setup and some extra equipment.
Cheers,
Jamie.
1st February 2012, 10:35 PM
Hi fellas,
The system that BJNSW is referring to looks just like the digital fuel adjuster kit and hand controller that jaycar sell in kit form
http://www.jaycar.com.au/productResu...11&SUBMIT.y=13
Adjuster
http://www.jaycar.com.au/productResu...x=0&SUBMIT.y=0
Hand controller
If your handy with a soldering iron it will save u a bit of cash.........
The Following 4 Users Say Thank You to Steve cooper For This Useful Post:
Darian (3rd February 2012), Gecko17 (10th March 2014), Paul Tkalec (9th March 2014), twisty (2nd February 2012)
2nd February 2012, 09:40 AM
$150 + fit and tune :-) and I can solder.
edit. "looks the same" ... looks exactly the same except for 2 IC stands and silk screening.
6th February 2012, 09:14 AM
Thanks Steve
For finding a cheaper option.
The guy from DFAS has only just replied to my enquiries after a negative ebay feedback over 3 weeks after I tried to contact him.
Would definitely recommend a DIY version from Jaycar as customer service on the DFAS unit was very poor.
Car still running very well after nearly 3000kls with new system.
Regards
BJNSW
7th February 2012, 03:24 PM
Good work but i don't see how richening it up under power throughout the whole rev range has enabled you to get better economy while cruising.
There doesn't seem to be any change in the AFR's. You could richen it up almost the same just using the overall adjustment on the ECUTalk.
Does the module allow you to adjust the fuel under different loads as well as rpm?
There is always nistune which allows you to alter the ignition timing as well.
7th February 2012, 03:44 PM
but.. you're going to supercharge it right? RIGHT??
:P
