29th January 2012, 04:18 PM
Snapped front body mount bolt GU
As the title says, the bolt was that rusty it snapped at the base of the captive nut when i was undoing it. this captive nut lies inside the radiator support panel and is difficult to access. does anyone know of an easier way of getting it out than cutting it out?
29th January 2012 04:18 PM
30th January 2012, 02:41 PM
You could try drilling then using a easy out remember to use lots of WD40 and let it soak in. If this doesn't work you may have drill out completly try not to damage the nut to much then run a tap through it to cut a new thread.
eg if its a 10mm bolt drill out to 8mm then run the 10mm tap through it.
30th January 2012, 02:54 PM
Call in an on site thread repairer, they're experts at this sort of job and have all the right gear.
Tony
30th January 2012, 03:22 PM
Moderator
YNOT
Tony
Hey Tony, Did not know this service existed??? where do i find such a man? I have one that is a big problem to me and beyond my tools or equipment.
A link would be awesome mate
Check out my Toy -->
Rogue Dung Beetle
30th January 2012, 03:44 PM
30th January 2012, 03:51 PM
30th January 2012, 07:55 PM
cheers guys, i think ill just cut it out. As i can not access the bolt from underneath.
