Page 972 of 1049 FirstFirst ... 4728729229629709719729739749821022 ... LastLast
Results 9,711 to 9,720 of 10488
  1. #9711
    WA Wheatbelt
    23 Post(s)
    Extreme Series light bars from @Lights
    Purchased 2 x 40" Extreme Series lightbars from @Lights and finally got them sorted, and they sit proudly on my bull bar.
    I just need to wire them up. Love em to bits!
    Had the roof painted this week, and have another bonnet to go on real soon.
    Last edited by DX grunt; 25th November 2020 at 10:57 PM. Reason: Trying to download pics, but it won't let me
    Quote Originally Posted by Mickhead View Post
    Mate that suggests the rim is unbalanced too, that is not ideal!
    It could suggest that yes. You would hope an experienced tyre fitter/mechanic would know this. Its as easy as removing the tyre and spinning the wheel up on the balancer to check. You could also do this check prior to fitting the tyre. Even go as far as to balance the wheel and then fit the tyre and balance again.
    I was also merely pointing out what jay see was trying to say amid the confusion.
    @mudski . Yes it could make it worse but you will never know unless you try. And more often than not these days guys will happily throw 100g+ of weight in one spot which seems excessive.
  4. #9713
    Are they on the outside of the bar DX
  5. #9714
    WA Wheatbelt
    23 Post(s)
    They are. Love them there. No reflections.
  6. #9715
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Can they spin just the rim on a wheel balancer to see if it has a balance issue? I've never seen it done, but ...?
  7. #9716
    194 Post(s)
    Swapped out the mechanical boost gauge today for a VDO electronic unit. The mechanical wasn't getting a good signal as the capillary line was restricted. New one is very reactive and boost is looking more like I expected it at 16 - 18psi out of the nominal 20psi pulley set that on the s/c, allowing for the press drop across the i/c
  8. #9717
    49 Post(s)
    Regarding the wheel balancing.
    Someone told me about the 180 degree spin years ago and never really worried about it until the last set of tyres that I brought. I mentioned it to the tyre shop and they did it. I did drive out with over $2k worth of tyres and rims.
  9. #9718
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Would recon as part of wheel rim new manufacture production lot acceptance, a random sample quantity would be subjected to a spin up balance compliance test.
    Recently also was experiencing 80-85 kph wobbles (33s M/T), balanced twice, pretty sure bearing were OK and then swapped fronts to rear and fixed.
  10. #9719
    472 Post(s)
    Bolted up a Sun Room for afternoon summer roadside Grandpa Spec naps
    The ‘Safeguard’ Mozzie net fits pretty well too
  11. The Following 9 Users Say Thank You to MB For This Useful Post:
    10G (30th November 2020), Bidja (28th November 2020), Cremulator (28th November 2020), growler2058 (28th November 2020), jay see (13th December 2020), Mickhead (30th November 2020), pearcey (28th November 2020), PeeBee (28th November 2020), Rossco (28th November 2020)
  12. #9720
    That would be the ultimate setup on a warm summers night under the stars once the awning is rolled away
  13. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (28th November 2020), PeeBee (28th November 2020)
