Page 874 of 1049 FirstFirst ... 374774824864872873874875876884924974 ... LastLast
Results 8,731 to 8,740 of 10481
  1. #8731
    461 Post(s)
    Interesting as Patrolapart recommended me to use silicone instead of a gasket for the water pump, it gets the fins closer to the timing case and helps with flow and cavitation apparently.
    Geez the difference would be less than quater a millimetre Chris. Considering the Gasket is a bee's dick over that. I doubt that would make a difference. But who knows for sure.
    193 Post(s)
    I agree. The gasket is a designated spacer of known thickness, where the silicone is anyones guess and if too thin may not seal for long anyway.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    mudski (18th November 2018)
  5. #8733
    472 Post(s)
    Silicone/Silastic would better seal pitting I would imagine?
  6. #8734
    193 Post(s)
    Can see the point, however the gasket is a surface seal, clamped with uniform pressure - or it should be if the thing is torqued correctly, so in theory, the pitting would be covered unless it goes to the edges of the hole and you have a channel from inside to outside, then a liquid seal would be better. Solid gaskets are not designed to deform as such, more cater for surface roughness values at best - I know sounds contradictory, but they will deform on a smallish level, not fill up depressions.
    MB (19th November 2018)
  8. #8735
    Jul 2015
    Camden NSW
    6 Post(s)
    Replaced the filter in my ProVent catch can. Old one looked OK for 80,000klms, the recommended replacement frequency.
  9. #8736
    Had a spazmotic idle when cold, ranging up to 770rpm.
    Disconnected the start battery and sprayed tho MAF.
    All seems to be OK now, happy with the outcome
    GQtdauto (19th November 2018)
  11. #8737
    461 Post(s)
    Quote Originally Posted by bazzaboy View Post
    I swap mine out at every 5k service and wash the old one ready for the next change. They obviously last longer than 5k but I just made it part of my service so I dont forget about it.
  12. #8738
    Jul 2016
    4 Post(s)
    It broke down for the first time on the weekend since its conversion.
    10,000 kay in on some hardcore trips including , snow, west tassie, high country and some hard core day trips...
    I dont know what it is but will get to it eventually
    https://youtu.be/NA1yj32XRvc
  13. The Following 9 Users Say Thank You to Baby Daddy For This Useful Post:
    AB (21st November 2018), Bidja (21st November 2018), gaddy (21st November 2018), MB (21st November 2018), mudnut (21st November 2018), PeeBee (21st November 2018), rusty_nail (21st November 2018), Touses (21st November 2018), Winnie (21st November 2018)
  14. #8739
    581 Post(s)
    Quote Originally Posted by Baby Daddy View Post
    Bugger mate, that wouldv'e been a pricey recovery but what a beast of a recovery vehicle!
  15. The Following User Says Thank You to AB For This Useful Post:
    GQtdauto (21st November 2018)
  16. #8740
    193 Post(s)
    I saw that vehicle drag a land rover out of the Caledonia River via Dingo Hill, did it like a walk in the park, amazing machines
