Page 1043 of 1049 FirstFirst ... 43543943993103310411042104310441045 ... LastLast
Results 10,421 to 10,430 of 10488
  1. #10421
    462 Post(s)
    Quote Originally Posted by pollenface View Post
    flushed my radiator until it was clean
    Probably something I should do while my Patrol is apart in the garage getting some love.
    MB (23rd January 2024)
    472 Post(s)
    Commenced degreasing and a hot pressure scrub a dub dubbing:
    Surface rust conversion completed and primer applied thereafter:
    First coat of black atop:
    A few more coats and the front end of our 3.9 ratio tourer for starters is ready for Australian beach shenanigans
  5. The Following 3 Users Say Thank You to MB For This Useful Post:
    Cremulator (23rd January 2024), growler2058 (25th January 2024), jay see (25th January 2024)
  6. #10423
    Apr 2021
    Brazil
    GQ UTE or GU wagon?
  7. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MB (24th January 2024)
  8. #10424
    472 Post(s)
    A NEW/Old GU Wagoon project BZ Brother
  9. The Following 2 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (24th January 2024), growler2058 (25th January 2024)
  10. #10425
    43 Post(s)
    Well now that I have the draws majority done I'm starting to work out the 12v stuff....
    No plan. Just doing it the Westbrook way..
    So I have run 5mm cable from main better to rear tripple anderson plug, which I feel may be a bit underdone but I'll keep an eye on it..
    Kickass dcdc25A charger with solar input.
    I landed on this product as it has a good wrap and price is good.
    I also had the victron isolated charger unit in the bascket but it's not compatible with alternator and solar, so would have to run 2 separate units which probably would have been ok but looking to keep this simple..
    I did however drop some coin on the victron shunt..
    I love the app and the way it tracks.
    So for now untill I sort the switches, this is how it will be. I can easily slide the draws in about out still with it all mounted which is key..
    For the switches I feel like going fancy with this one... anyone used something like this??
    I like that ist the switch bank, and fuse bank all working together. A touch nicer than rocker switches...
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MB (26th February 2024)
  12. #10426
    194 Post(s)
    Bit of an odd one. I have done a body swap and chop on the GQ. The original car was a 1997 model and I have used that interior. The donor was a 1991 body, that was chopped. Today I started the final prep before driving it out of the shed and getting ready for VASS engineering. I tried to get the rear seats to latch onto the floor latches, using the 1997 back seats and the 1997 catches. They required the mounting holes slotted to get the latch to land in the middle of the seat catch. All looking good except the seat catch wont receive the latch on the floor. I stuffed around for 6 hrs with this today, tried all sorts of packing and optimisation, had @AB and @MB have a look, baffling. I am fabricating a floor stiffener tomorrow morning as a packer to go right across the rear floor and pick up the two floor catches i case the floor is flexing.
    Has anyone come across this before? the 1991 floor catch is way too short to operat1991 in front 1997 in rear.jpge and too low in height to pick up the seat catch. Couple of pics for clarity. I need a solution or the car wont pass the inspection.
  13. #10427
    109 Post(s)
    Fck cars pb. When you think you’ve been through all they can dish out, they find another way to fck with your mental well-being. Honestly to come down to this mate you are in my thoughts.
  14. The Following User Says Thank You to Plasnart For This Useful Post:
    PeeBee (24th February 2024)
  15. #10428
    194 Post(s)
    Thanks Plassy, its fighting me right to the end. Spending 6 hours solid trying to think and react without a positive outcome, its exhausting, far worse that doing the physical. The journey has had its moments that is for sure. the end product will be good, but there are still hurdles to get over. Its been 2 yrs on this, far too long and more than enough patience expended by @MB to let this continue.
  16. #10429
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Can you get an inspection camera under there to see where it doesn't connect?
  17. The Following User Says Thank You to BillsGU For This Useful Post:
    PeeBee (25th February 2024)
  18. #10430
    194 Post(s)
    ok, would you believe there are 3 versions of the same catch? Yes, well there is and I have one pair of each. I found the third set this morning after stewing over the impossibility of the catch not fitting in the set clasp. I swapped the third set out and the seats went 'click, done. Happy days.Catches.jpg
    The third set is made from a smaller diameter rod, so it allowed the catch to close.
  19. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    BigRAWesty (28th February 2024), BrazilianY60 (26th February 2024), Cremulator (25th February 2024), mudnut (25th February 2024)
