Page 1002 of 1049 FirstFirst ... 2502902952992100010011002100310041012 ... LastLast
Results 10,011 to 10,020 of 10488
  1. #10011
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Finally got around to making and installing the shelf for the rear door. All from bits and pieces I had on hand except for the piano hinge. Even set up a light up top. Tried it out in anger during a few days away last week. I'd call it a success.
  2. The Following 10 Users Say Thank You to Brissieboy For This Useful Post:
    10G (10th May 2021), Cremulator (9th May 2021), Hodge (9th May 2021), jay see (9th May 2021), MB (11th May 2021), Mickhead (12th May 2021), mudnut (9th May 2021), Rossco (9th May 2021), rusty_nail (16th May 2021), Stropp (25th May 2021)
    May 2016
    lower west victoria
    30 Post(s)
    Nice work, very neat.
  5. #10013
    Feb 2014
    Southern Tasmania
    The old rusted sliding window frames have been bugging me as has the tired interior door cards. Gone solid glass and new 2mm thick plastic cards. Looking less like a shit box both inside and out.
    Next are new injectors and glow plugs.
  6. The Following 5 Users Say Thank You to gazq For This Useful Post:
    10G (17th May 2021), MB (16th May 2021), mudnut (16th May 2021), PeeBee (17th May 2021), Rossco (16th May 2021)
  7. #10014
    Advanced Dasa's Avatar
    Aug 2019
    North central VIC
    Recently had a snorkel installed and picked up a carry me camper which lead to needing a reversing camera.
    Squeezed the CIG power plug into the overhead light panel
    Then had to swap the power from battery to accessory in the fuse box which also took out the clock but there is plenty of other clocks including one in the mirror which has its own battery.
    GPS unit stuck to the dash with wires tucked behind the windscreen rubber.
    12" mirror was a snug fit so I chopped a bit off the sun visor mount so that they could sit out a little wider. Then I moved the mirror mount a bit and ground it down so that it sits higher and closer to the windscreen but then it needed a bit more chopped off the end so that the overhead lights would fit back up.
    IMG_20210524_084328_4.jpgIMG_20210524_090940_9.jpgIMG_20210524_090953_1.jpgIMG_20210524_091211_5.jpg
    Wire for the rear camera is routed around the windscreen rubber to the top of the drivers door trim then out below the rear window and ended up with a foot or two to spare.
    For anyone that is interested it is a WOLFBOX Mirror Dash Cam $190 on amazon.au
    Also the Snorkel dropped EGT ~40c probably more in hot weather when it is borderline boiling.
  8. The Following 9 Users Say Thank You to Dasa For This Useful Post:
    Cremulator (24th May 2021), growler2058 (24th May 2021), MB (25th May 2021), mudnut (24th May 2021), mudski (24th May 2021), PeeBee (24th May 2021), Rossco (25th May 2021), Stropp (25th May 2021), Touses (24th May 2021)
  9. #10015
    472 Post(s)
    What did you do to your Patrol today!
    Beaut Stuff @Dasa Mate
    Would be keen to see some piccies of your new tray camper too if and when time possibly permits
  10. #10016
    Keen to see what you think of that camera unit after a little bit of time mate, it looks awesome and the price is right. I need to do something in my wagon.
  11. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (25th May 2021), Stropp (25th May 2021)
  12. #10017
    22 Post(s)
    I made a little frame up to house my compressor and tank. I just need to sort some conduit and an anderson plug out for the supply cables and it'll be good enough for a bit
    Once I get my new canopy, that whole setup will end up on runners and built into a bigger frame with outlets between the tray and cab
    96 GQ coil/Cab
    08 G6eT
  13. The Following 7 Users Say Thank You to Ben-e-boy For This Useful Post:
    Cremulator (25th May 2021), Dasa (28th May 2021), MB (25th May 2021), Mickhead (26th May 2021), mudnut (26th May 2021), PeeBee (25th May 2021), Touses (26th May 2021)
  14. #10018
    472 Post(s)
    Fark me, I think I get what you mean Ben Mate, and that is as Daz would say: “next level” Love IT
    I’m assuming you’re temporarily running the system in the work tray for now until 100% happy before next Legendary Steps.....can I copy oneday too please Bloke
  15. #10019
    Expert Mickhead's Avatar
    Oct 2019
    How the fridge does a cam snap, surely that can only be shitty material can't it????????????????
    Nah, bolt left loose by a shitty mechanic who replaced the head years ago before I owned it. Removed head, cleaned stuff, we can rebuild it!🤪💩75B7CDEA-799D-4785-A374-7218D5E426A7.jpeg
  16. The Following 6 Users Say Thank You to Mickhead For This Useful Post:
    Avo (26th May 2021), Cremulator (26th May 2021), MB (27th May 2021), mudnut (26th May 2021), mudski (27th May 2021), rusty_nail (26th May 2021)
  17. #10020
    462 Post(s)
    Quote Originally Posted by Mickhead View Post
    You've obviously said F*$k you to this motor once or twice before. The motor has left a little message in response on the front piston I see.
  18. The Following 5 Users Say Thank You to mudski For This Useful Post:
    Cremulator (27th May 2021), MB (27th May 2021), Mickhead (27th May 2021), PeeBee (27th May 2021), Rossco (27th May 2021)
