Page 810 of 1049 FirstFirst ... 310710760800808809810811812820860910 ... LastLast
Results 8,091 to 8,100 of 10488
  1. #8091
    drove it..it sucked.....like a brick tied to an anchor....my harley has more horsepower......and it doesn't have tpo tow 3 tonne around
    194 Post(s)
    Quote Originally Posted by perfectlift-tips View Post
    Just exploring www for pretty nice lift kits, any guess on the lift kit provided by https://www.perfectlift.com.au
    Hey there, are you a spammer? None of these kits appear to suit patrols, and you seem on a promotional journey? happy to be corrected.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    GQtdauto (2nd December 2017)
  5. #8093
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Nothing to the patrol apart from more fuel but did the wheel alignment on the camper trailer , both wheels scrubbing on the inside but independent suspension pretty easy to do .
  6. #8094
    194 Post(s)
    swapped over a new viscous fan coupling - ugly ugly ugly, 3 hrs, 6 beers and bleeding knuckes. Don't remember the deal with the old patrol engine but the chev is very tight - need fingers like ET and uni-jointed 5 ways to get the bolts in and started. Hope this is the last time I have to do this. Attacking the shredded difflock hoses and wires tomorrow along with the mangled cruise control cable
    MB (2nd December 2017)
  8. #8095
    194 Post(s)
    Repaired the wiring and airlines from difflock compressor. Made an extended fan shroud to improve efficiency of the new fan blade. DSC01934.JPGDSC01935.JPG Before and after shots of fan shroud.
  9. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (2nd December 2017), mudnut (3rd December 2017), MudRunnerTD (3rd December 2017), Rossco (2nd December 2017), Yeti's Beast (2nd December 2017)
  10. #8096
    194 Post(s)
    Earlier in the week when I changed over the fan coupling I 'lost' a 13mm open ender under the bonnet - it slipped out of my hand, went clank a couple of times and then could not find it. Anyway, still missing today and when i backed the truck out of the garage to reposition it, there was the worst vibration, then moved forward, nothing, reversed, vibration, did this a couple of time, thinking there was a porblem with the gearbox. Anyway got out and stuck my head under the vehicle and there was the spanner, sitting on a ledge partially exposed. Removed it and problem went away - if only every issue was as simple.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (2nd December 2017), mudnut (2nd December 2017)
  12. #8097
    Jul 2013
    I replaced the deep cycle battery, with a SSB 100Ah Dry Cell AGM Deep Cycle.
  13. The Following 3 Users Say Thank You to Bush Ranger For This Useful Post:
    GQtdauto (2nd December 2017), Patrol-Guy (3rd December 2017), Yeti's Beast (2nd December 2017)
  14. #8098
    194 Post(s)
    Quote Originally Posted by Bush Ranger View Post
    Hi BR, couple of questions for you if I may;
    1) why did you go for this 'style' of deep cycle, as opposed to the wet cell plus. Are they faster recovery or better life under deep depth of discharge?
    2) I am confusd with the description - dry cell AGM - what exactly is the format - I thought agm was a gel type of filling, and dry cell, closer to a carbon battery with limited moisture? I don't know enough about battery chemistry to tell the difference.
  15. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Bush Ranger (3rd December 2017), Patrol-Guy (3rd December 2017)
  16. #8099
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    What did you do to your Patrol today!
    Agm batteries do recover faster and can be discharged lower than a wet battery. They also have a longer shelf live where they will retain their charge longer when not being used.
    Due to the surface area of the plate being in direct contact with the acid which is soaked into the separator, it ensures that every part of the plate is working without the possibility of acid stratification. The plates have lower internal resistance allowing greater performance.
    Here are some pics of an AGM I cut down for examination
    The white colored material is soaked in acid and is one length that is folded to go around every plate in the group.
    This is the separator partially unfolded
    Depending on the manufacturer AGM batteries are much higher quality batteries compared to your usual wet battery
    As a rule AGM batteries don’t like heat, they performed at their best if kept under 25c
    These batteries came from a data center where the temp is maintained by an air con set to 25c.
    In this environment these batteries have a 10 year design life.
    We recommend that AGM if used in automotive applications should be fitted inside the rear of a car or inside a camper/ caravan to get the longest life. They will work under the bonnet but the life time is decreased by the high engine temps.
    Most GEL batteries are AGM batteries that are topped up with a Gelified Acid to help keep them moist for use in higher temps and Carbon Batteries are basically an AGM Battery also with Carbon added to the plate.
  17. The Following 5 Users Say Thank You to Yeti's Beast For This Useful Post:
    Bush Ranger (3rd December 2017), GQtdauto (3rd December 2017), MudRunnerTD (3rd December 2017), Patrol-Guy (3rd December 2017), PeeBee (3rd December 2017)
  18. #8100
    194 Post(s)
    Thanks for that, really solid info.
  19. The Following User Says Thank You to PeeBee For This Useful Post:
    Yeti's Beast (3rd December 2017)
