Page 987 of 1049 FirstFirst ... 4878879379779859869879889899971037 ... LastLast
Results 9,861 to 9,870 of 10488
  1. #9861
    Thanks Legends, great learnings as always appreciated
    Not sure how well the vacuum closing design of the valve is going to work if I accidentally stall the truck half way through a deep river or in the middle of a shocking bog hole though
    Wouldn’t that be exactly the same as the bath tub nuffy test?
    There is nothing wrong with what you have done and what you say is right. The valve is ineffective without the engine running. Just pointing out its operation.
    Engine protection aside. Be careful when attempting to cross anything that is deeper than the bonnet
  2. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    MB (5th February 2021), MudRunnerTD (5th February 2021)
    Wipers On! Windows Up! #Justsendit
  5. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (5th February 2021), nissannewby (5th February 2021), Rossco (5th February 2021), rusty_nail (5th February 2021)
  6. #9863
    472 Post(s)
    Wipers On! Windows Up! Snorkel Ram Head Backwards! #Justsendit
    Fixed it for you @SwampNutterTD
  7. The Following User Says Thank You to MB For This Useful Post:
  8. #9864
    109 Post(s)
    Hahahahaha. Plas you need to come for a drive in my GU mate....... i show you happy Dance brother! Lol
    Haha as a jockey I reckon 4k would be sweet!
  9. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (6th February 2021)
  10. #9865
    194 Post(s)
    Once again I know ‘nuffing’ about this stuff but really enjoying/appreciating learning here Legends
    I do remember when I burst the seams on my GU rear main tank on a rock and had to quickly externally plumb the filter pickup line out through the bonnet corner and direct like a syphon hose into the forward auxiliary tank filler nozzle to get up and out of the shit quickly.
    Philstar you kindly educated me then that some huge amount (can’t remember %) of diesel delivery volume heads immediately back to the main tank of which could be the filters overall rated needs if that makes nuffy theory sense?
    Certainly the main rear tank gauge filled up quickly climbing out but we were back up onto flat highway country by then to re-plumb the system back to standard and use the 1/3 full to get back home safely
    @MB, yes my flowmeters show an over supply anywhere from 90% downwards returning tank to around 70% on my motor.
  12. #9866
    472 Post(s)
    So....I’m back in love again with the new airbox after easy installation this afternoon, thanks heaps again Mat for the top product suggestion and apologies Gentlemen & ‘Black Mamba’ for my late night sook up earlier here
    As mentioned, a piece of piss to install and plenty of wriggle room to choose left/right/forward and also backwards too if you move your GQ overflow bottle as they advertise:
    (I settled on slightly backwards and slightly right twisted out off the guard a whisker so that my 10mm socket could whip the top off fast if ever needed)
    Reduced it down for now from 4” to 3” via the first 90 degree bend only because I had all the 3” gear leftover from the previous setup trials.
    Design angles out of the top of the airbox are absolutely perfect and it could easily clear a TD42t GQ alternator vacuum pump with 4” piping all the way through if needed folks
  13. The Following 2 Users Say Thank You to MB For This Useful Post:
    10G (9th February 2021), Rossco (6th February 2021)
  14. #9867
    472 Post(s)
    Next project is to finally install the little mini ARB pump to solely run lockers and the old winch freespool.
    Can’t really be bothered mounting/wiring it safely inside the cab as have done on other trucks before so are playing around with shielding it from exhaust heat somewhere around here:
    Do any of you Legends kindly know if there is any possible detrimental diesel engine affects of plumbing the little compressors clean air intake into the airbox top so it doesn’t get swamped out there too?
  15. The Following 2 Users Say Thank You to MB For This Useful Post:
  16. #9868
    192 Post(s)
    Awesome Markie, she's com'n along nicely. . . Wouldn't think their should be an issue running into airbox, surely there'l be enough air to go around doesn't take much to activate diffs and freespool. . .
  17. The Following User Says Thank You to Rossco For This Useful Post:
  18. #9869
    472 Post(s)
    Cheers Rossco Mate, have been thinking the same since posting as it should barely kick in unless I have an unfortunate sneaky line leak in the system somewhere as they can known do
    There’s no possibility that something inside the compressor could shite itself and head on into the engine, I have no idea what’s inside these thingys although maybe a cheapo fuel filter in-line between could trap anything untoward heading back in?
    Think I’m possibly overthinking it too much now too
  19. #9870
    49 Post(s)
    Another tyre rotation today.
    Decided to go back through my service book to see how long I've had these.
    Purchased on 05/07/16 with Speedo reading 285272 km.
    Speedo is now at 366084 + 16558 when I had no Speedo, so
    366,084 + 16,558 = 382,642 - 285,272 =
    A grand total of 97,370km in 4 years and 7 months. In that time I've rotated all 5 tyres between 7 - 10,000km. This was the 9th time. Unfortunately they have only seen the tracks about 1/2 a dozen times the rest has been on the block top.
    Not know why, but 4 of them are like the first pic and the other is the 2nd pic, can't really see it in the pic, but the 2nd does have more meat and is less cambar..
  20. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (6th February 2021), mudnut (6th February 2021)
