Page 935 of 1057 FirstFirst ... 933934935936937 ... LastLast
Results 9,341 to 9,350 of 10561
  1. #9341
    Reconfigured the old family wagon this afternoon since removing the Titan 85kg drawers a month or so ago now.
    Managed to squeeze in so far:
    80L Waeco old fridge
    26L Engel freezer
    2 x 20L HDPE water jerry cans
    1 x camp stove
    1 x camp table
    1 x 120W Waeco old solar kit
    4 x Expedition boxes up top.
    Will fill in all the leftover nooks and crannies tomorrow now with bits and bobs and reckon sleeping bags and self inflator mattresses should jam up on top of 3 x Expedition boxes to the ceiling before dropping in the final fourth awesome box!
  2. The Following 3 Users Say Thank You to MB For This Useful Post:
    Clunk (13th January 2020), MB TD42 (12th January 2020), Yeti's Beast (11th January 2020)
  3. #9342
    Approximately 1.5 sheets of ply used, and is relatively easy to install/remove if need be as long as you have the left barn door aftermarket bracket to open wider than stupid GU OEM design!
  4. The Following 2 Users Say Thank You to MB For This Useful Post:
    10G (10th January 2020), Clunk (13th January 2020)
  5. #9343
    May 2016
    lower west victoria
    30 Post(s)
    Champion effort MB, great work. It's harder than you think cramming stuff in the back, you've done well.
  6. The Following 2 Users Say Thank You to 10G For This Useful Post:
    MB (10th January 2020), Winnie (10th January 2020)
  7. #9344
    I like that a lot MB, very well done and practical! I am thinking of making some changes to my rear setup.
  8. The Following User Says Thank You to Winnie For This Useful Post:
  9. #9345
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    x 2 on that @MB . I've been thinking of what to replace those drawers with. Handy, but otherwise just weight and storage hogs. That looks super simple and practical(and cheap!). Good job
  10. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
  11. #9346
    Cheers Blokes!
    Forgot to add that I needed to extend forward 80mm this specific brand GU cargo barrier to fit the second rear row of Expedition boxes.
    They fit like a pair of good gloves now
    FWIW: The ply box outer dimensions today were:
    1125mm Wide x 930mm Deep x 540mm High and used 3 of the 6mm OEM bolt holes in the floor to secure down.
    (There is a niggly notch on the floor sheet that needs to be cut out located on the right side pictured below)
  12. The Following User Says Thank You to MB For This Useful Post:
  13. #9347
    Great little stash spot for spares:
    #Complete set of belts
    #Complete set of hoses, including heater ones
    #Some thermostats to play around with
    #Spare manual hubs (thanks for the lend @rusty_nail mate)
    #Unfortunately air filter spare doesn’t fit, too fat.
  14. #9348
    Can still access the OEM jack as a backup which was a bit of a fluke :-)
  15. #9349
    Expert Mickhead's Avatar
    Oct 2019
    Started some serious playing with dawes and needle valve. First attempt a couple of days ago had the boost gauge dancing all over the place. Tigged in a second boost take off point rather than tee into the gauge line and things are looking better!
    EGTs are nice, but a boost spike if I floor it from standing.11A3F6F2-48FF-4264-B28E-F408495989FF.jpeg07B16C24-4B7D-447C-AB0F-3C9585A1FEA3.jpeg
  16. The Following 2 Users Say Thank You to Mickhead For This Useful Post:
    MB (11th January 2020), rusty_nail (11th January 2020)
  17. #9350
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Pulled the radiator out and gave it a good clean, as I’ve noticed the temps creeping up on the hills. I also put in a TB48 Thermostat, which is a job I never want to do again!. Changed the Tensioner and belt while I was there, will finish it all up tomorrow hopefully.
    No wonder she was heating up, still had the remnants of an off track trip stuck in the radiator! Was a mission getting all the spinifex out, but should be good to go now
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  18. The Following 3 Users Say Thank You to stevemc181 For This Useful Post:
    MB (11th January 2020), Rossco (11th January 2020), Yeti's Beast (11th January 2020)
