Results 1 to 5 of 5
Thread: GQ SWB Rock Sliders
    GQ SWB Rock Sliders
    has anyone made themselves a set up sliders for their SWB GQ? i was lookin at the chassis rails under mine the other day and they dont look easy to bolt onto. does anyone have any fantastic solutions to get around this?
    Advanced
    Jan 2013
    Apr 2014
    I am in the process of doing a set for mine. I bought a slider kit for a SWB which turned out to be the worst piece of engineering I have seen so in the process of starting from scratch.
    Like you, currently working out the chassis mounts. Most I have looked at are not exactly what I would call substantial so working it out. But as you say, there is not a lot of room to work with.
    The part that has me most 'concerned' is the rear mount as it leaves a far bit of the slider at the back unsupported.
    Patrol Guru
    Apr 2011
    Melton
    On my lwb,
    I had u brackets made at a local metal place out of 10 mm plate.
    The U brackets are long enough to be fit bolts above the chassis rail.
    I used a simalar beacket for the front as per the link
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  6. #5
    Surdex steel sell some cattle yard steel that would be perfect
    for sliders, about 6" x 1" with rounded ends not square.
    Will make awesome sill savers IMO
