Results 1 to 10 of 18
Thread: Rear LED Light fitted
    Advanced knakkers's Avatar
    Hampton Park
    Just complete a little DYI project to my GU Patrol, fitted a rear "LED light (5x3w) 1050 lumen output" for reversing in the dark or while out camping. It is a very bright light, probably too bright. More then happy with it.
    It was pretty easy to mount & wire up, once i worked out exactly how i wanted.
    I mounted it off the spare wheel carrier bracket.
    Used a piece of 3/4" box steel tubing, measured the height, cut the steel, drilled holes to mount to the spare wheel carrier bracket, painted it etc.
    Mounted the LED light to the top the tubing, fed the wire down inside the tubing. Also put rubber plugs either end of tubing with holes drilled into them with small water tight gromits for the wire to run threw.
    Drilled a small hole in the back door, with small gromit for wire to feed threw, then fed the wire threw the car to a switch in the dash. Then a wire from the switch directly to the battery with a 30amp fuse in between.
    At the end of completing the little DYI, i was pretty happy with the end result on how neat & tidy it all looked.
    It did take up all of Saturday morning running around to purchase all the different bits & pieces i needed from different shops. Then on Sunday it took about another 4hrs from start to finish to install
    Now Divorced I can do what i like when i like. How good is life now
    02 GU111 Patrol 3.0TD Man, Chipped, Redback 2.5" Exhaust, Safari Snorkel, OME 2'' Lift, ARB W/Bar, Tigerz11 12000Lb Winch & R/Rack, IPF Lights, Cooper S/T Maxx 33's, Dual battery system, Uniden UHF, ARB fridge/freezer on ARB Slider, & heaps more
  2. The Following User Says Thank You to knakkers For This Useful Post:
    Bluecrab (9th June 2013)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    looks good mate nice and neat
    Perth WA
    Just about to do this with almost same light but round. Just wondering what everyone else has done with the wire thru the rear door... Nice install by the way
    2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
    462 Post(s)
    Where did you get the lamp from?
    Hampton Park
    http://www.brightlightautoparts.com/
    You can also purchase off ebay from this company, but i purchased cheaper by going direct to the shop & got very helpful info
    Hampton Park
    Quote Originally Posted by adventurepaul View Post
    I just drilled very small hole with tight gromit in the door. Or the option is, find someone with a lathe & drill a small hole in the centre of, one of the bolts that mount your spare wheel carrier onto the back door
  9. #7
    Western suburbs of Melbourne
    11 Post(s)
    Good job, need this to reverse the boat
  10. #8
    NE Victoria
    Nice neat install do you have it plumbed into the reverse lights or just a switch on the dash? Give those pesky tailgaters a nasty suprise!
  11. #9
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Nice job mate, looks tops.. Will make reversing alot easier at night Haha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
  12. #10
    Hampton Park
    Separate switch in dashboard wired directly to battery. So I can switch on when ever I like. Yeah it's good for anybody that tailgates or hi-beams me from behind. Lol
