Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: "nads"
  1. #21
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    That clears that myth up then Tony.
    Cheers, the ferret.
    How do I go about having the NADS done on my 99 GU 2.8lt TD?
    Is it something I need the mechanics to do or can I do it myself?
    Any links would be helpful.
    From what I've read it only concerns the 3lt Di 2000-2003 and all Di, you might ask if the EGR block is worth while on your engine, I'd think so
  5. #24
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by Jamesandlizk View Post
    Yep, block the EGR, easy, fit catch can ,easy, remove butterfly, easy. That's about all you need to do with the 2.8.
    The main aim is to prevent oily carbon buildup within the inlet manifold and to help keep the Maf sensor clean.
    Cheers, the ferret.
  6. #25
    Cheers guys once again, very helpful advice.
  7. #26
    Just so you guys know, we sell a product that plugs onto your airflow meter and is plug and play for 2000-2003 DI Patrols that stops the car going into limp all together. Fitting your NADS will work but for someone looking for an easy 5minute solution give me a PM and I can help you guys out
    Cheers,
    Adam
  8. #27
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by DieselSmart View Post
    Cheers,
    Adam
    Sounds good Adam, what about posting up a bit more info on the product, sounds interesting.
    Cheers, the ferret.
  9. #28
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    X2 would like to know more
  10. #29
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    Nissan not blowing up engine system
