20th January 2012, 12:13 PM
#21
Hardcore
That clears that myth up then Tony.
Cheers, the ferret.
20th January 2012 12:13 PM
16th August 2012, 11:19 AM
#22
How do I go about having the NADS done on my 99 GU 2.8lt TD?
Is it something I need the mechanics to do or can I do it myself?
Any links would be helpful.
16th August 2012, 11:24 AM
#23
From what I've read it only concerns the 3lt Di 2000-2003 and all Di, you might ask if the EGR block is worth while on your engine, I'd think so
16th August 2012, 11:33 AM
#24
Hardcore
Jamesandlizk
Yep, block the EGR, easy, fit catch can ,easy, remove butterfly, easy. That's about all you need to do with the 2.8.
The main aim is to prevent oily carbon buildup within the inlet manifold and to help keep the Maf sensor clean.
Cheers, the ferret.
16th August 2012, 11:57 AM
#25
Cheers guys once again, very helpful advice.
16th August 2012, 01:50 PM
#26
Just so you guys know, we sell a product that plugs onto your airflow meter and is plug and play for 2000-2003 DI Patrols that stops the car going into limp all together. Fitting your NADS will work but for someone looking for an easy 5minute solution give me a PM and I can help you guys out
Cheers,
Adam
16th August 2012, 02:55 PM
#27
Hardcore
DieselSmart
Cheers,
Adam
Sounds good Adam, what about posting up a bit more info on the product, sounds interesting.
Cheers, the ferret.
16th August 2012, 07:54 PM
#28
X2 would like to know more
9th January 2014, 11:29 PM
#29
Nissan not blowing up engine system
