4th September 2010, 02:05 PM
Bitumen Burner
Head gasket
My 2005 GU DX ute has done about 205,000km, and my mate reckons it needs a new head gasket.
Here's the pics. What do u reckon.
It does make a click click noise. It mainly does it while accellerating, and quite often when cruising. It will do it at some speeds but not others, and never does at idling?
Comments please.
4th September 2010 02:05 PM
4th September 2010, 04:44 PM
I say your mates wrong, it's just an exhaust leak. If it was a head gasket it would be miss firing. Take the heat shields off and have a close look. While the heat hields are off get someone to start the engine and give it a rev if necessary, and see if you can feel where the leak is coming from.
Tony
4th September 2010, 04:51 PM
I agree with Tony, A manifold leak or even a small flange leak is more likely the issue here & a much, much cheaper fix to I might add.
4th September 2010, 06:33 PM
Bitumen Burner
YNOT
Tony
You guys (Tony & Paul) are legends and I hearby give you one credit infraction !!!! lololol
13th December 2010, 08:47 PM
Just a exhaust leak but don't leave it to long it will torch out the flange
Cheers Steve
