3rd September 2010, 07:50 PM
Ignition System
Howdy all,
I am having issues With getting a spark,
i think that the coil may have died but i am curius as to what volatges i should get and where.
Hope the pic works
currently i think htis is how it is wired, and i am getting,
at "a" - 4 volts
at "b" - 4 Volts
at "c" - 12 with igntion
the coil is brand new, and it measures 1.3 Ohm across the 2 terminals and
10k between the Center teminal and the outer terminals
does this sound ok?
done alot of searching to no avail... i more confused now than before...
Thanks in advance
Aaron.
3rd September 2010 07:50 PM
3rd September 2010, 08:18 PM
OK it sounds like your resistor has bit the dust. you should have 9v at a & 12v at a in crank (start) so I would suggest you change that (around $7 to $10 not hard to do either
Paul
3rd September 2010, 08:50 PM
I agree with Paul, sounds like a faulty ballast resistor. Make sure your new ignition coil is compatible with ballast resistors (it may have an R in the part number somewhere eg. GT40R)
Tony
3rd September 2010, 10:19 PM
The coil is the Standard one that Repco Gave me... i will get a new one anyway i think. Thanks Guys
4th September 2010, 02:24 PM
Ok so i got a new coil and a new resistor, and Boom off she went
prety sure the old coil is ok but i thought i'd do it anyway, i got the GT40r and 1.6 ohm balast.
The balast that was in ther ewas meant to be 1.6 but was reading bout 5 ohm
Thanks Heaps Guys
Aaron.
4th September 2010, 02:45 PM
Good stuff Aaron glad you got it sorted mate..... Now its back to happy 4x4ing...lolol & you've learned something new along the way.
Good onya mate for posting back to let us know how you got on.
Paul
