Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Battery installed by Idiot, ME.
Hybrid View
    Advanced rockndot's Avatar
    clarence valley
    Hi guy's, I had a brain fade the other day, was installing new battery,(Old one keep going flat) but it was raining and i just threw the new one in, didint take any notice and ...well the rest is obvious, a small spark when i attached the earth terminal to the positive , i thought yes you bugger there must be a small short, look into u later. went to start no power, angain obviously..........
    gave myself a rather long talkin too, and started to chase fuses,
    Main ignition 65 amp blown next to battery,and 15 amp fuse inside at kickboard ECU engine control unit 15 amp,
    Have breached the main fuse with ......., so now have ignition and dash lights to all but Glow light, and battery in engine will wind over and over but willnot start.
    I am thinking solinoid or another fuse ?
    Also the ECU fuse blows again.
    I have Gregorys manual for the car , but not much elec knowledge, but hey i'm here to learn and help if poss, will be grateful to any tips in sortin this out.
    Nov 2011
    im a sparkie and reverse polarity is not a good thing, i think the ecu may be fired as it keeps blowing your fuse. i hate to be the bearer of bad news but i think the repair bill is going to be hefty. i know for a fact but stereos dont work after conecting them backwards, dont ask me how i know but as you turned the key with the battery backwards everything in your car has seen reverse voltage, so anything with electronic in them are probably buggered, hopefully you did not have a cb or anything too.
    i would first pull a spark plug lead and see if you still got spark. then see if your fuel pump still operates.
    hopefully someone else chimes in and its an easy fix but i think at a bare minimun your up for a new ecu.
    clarence valley
    yeah thanks, Bobbrumby,
    i figured about the same, will remove it and get it checked, there should be some arround the wreckers i'm hopping.
    but any other people who have an idea would be happy to hear.
    P.S. it is a diesil non turbo
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Isn't the idea of a fuse that it blows first, before ecu's and other sensitive equipment blows up.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Ian2011 View Post
    In automotive use the fuse main purpose is to protect the vehicle wiring from overheating and catching on fire if a short in the circuit occurs.
    They are know as a slow blow fuse and even though they have a rating of say 15 amps under the right conditions it might not blow until it reaches 18 amps.
    ECUs will have protection built in them for under voltage supply, over voltage supply and voltage spikes.
  6. #6
    Nov 2011
    sorry thought it was a petrol, hopefully the glow plugs and stuff all come out of the one box, but i have no further if any knolledge on diesels, good luck.
  7. The Following User Says Thank You to bobbrumby For This Useful Post:
    rockndot (4th January 2012)
  8. #7
    581 Post(s)
    I guess the good news is that It's a diesel in that situation.
    Hows the glow plug fuse link going next to the 65amp one you blew?
    Is that soft and not burnt?
    If It's hard as a rock and looks burnt then could be an issue?
  9. The Following User Says Thank You to AB For This Useful Post:
  10. #8
    clarence valley
    Hi there AB, thanks for havin alook at my issue, the Glow plug fuse link is still good,
    But i think i may have had a little moment to think harder and ....
    When i went to the fuel section (because i can crank it over, so fuel had to be the issue),
    it showes me a apth to follow, starting at the ..oh well it starts on page 81 item 8,
    Preheat system.
    will keep all updated as i progress or stall, lol.
  11. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    What model Patrol are we talking about? is it a GQ 4.2 diesel?
    If so, the 15 amp fuse I think you are referring to, also supplies power to the injector pump, this would explain why the vehicle is not starting.
    I would start by disconnecting the glow plug timer control unit (under fuse box inside vehicle) and see if the 15 amp fuse blows again.
    If it doesn't blow, I would retry starting it, at the moment it should start without glow plugs but to be on the safe side you could supply direct power to the glow plug rail (busbar) for about 15 seconds and then try cranking it.
    There is also a small possibility that you have damaged your alternator
  12. The Following User Says Thank You to Yendor For This Useful Post:
    rockndot (5th January 2012)
  13. #10
    clarence valley
    Hi Yender, 1st up yes it is 89 42 diesel.
    Me not being very electricly minded , have viewed the wiring diagram and see what you are sugguesting,
    i will try this 1st , was then going to just try and supply the injector direct from battery and see if she would kick over.
    weather is right to try and start without glow if in middle of day and have a good new 760cca battery to use also
    once again thanks for the tips guy's,
