Results 1 to 10 of 11
Thread: front end head shake
    Advanced Ferret's Avatar
    Jul 2012
    hey guys I drive a SWB mk patrol tonite I was driving down the freeway come to about 80 kmh and my front end started shacking like all heck my steering was going left and right like a mad man on heroin it's either I power through to 90 100 and it'll go away or back off i have no clue on what this problem is or what could source it any answers will be helpfull thanks guys oh and this problem doesn't occurre all the time only once in a blue moon.... thanks
    mk patrol sd 33turbo diesel, bullbar, roof racks, driving lights, efs 2 inch lift, 35" Federals, Rear qtr chop.33" led lightbar..
    Benarkin QLD
    Itll be the front end shackle pins and bushes,or a tyre getting some age and the belt starting to let go ......
    If it was an unbalanced tyre/wheel itll shudder slowly and increase with speed
    Check your tyres , they have manufacture dates on the sides,if their old that could be it
    But the front shackles, bushes and pins id say are stooofed
  4. The Following 2 Users Say Thank You to MQ MAD For This Useful Post:
    Ferret (13th August 2012), patch697 (13th August 2012)
    Jul 2012
    thanks mate
    Banned
    X2 on MQ Mads post
    22 Post(s)
    Chect the locator pin for the leaf spring to the diff and the u bolts while you are there
    96 GQ coil/Cab
    08 G6eT
    Jul 2012
    my leafs shocks and shackles are all rooted badly if this helps not sure leafs are dead front and rear my bum stops are touching diffs lol
  9. #7
    Check the inside walls of your tyres one may have a huge bulge about to pop.This is a Major problem that needs addressing ASAP
    X2 on bushes you may be running metal to metal
  10. #8
    Apr 2011
    Melton
    All of the above.
    To check the king bearings, jack a tyre up.
    King bearing / swivel bearngs - Grub hold of the tyre at 12 and 6 then push back wards / forwards is there any movement.
    wheel bearings - grub the tyre at 3 and 9 push back wards and forwards any movement
    Also check the welds on the chassis where the schakle eyes are
  11. The Following User Says Thank You to GQ TANK For This Useful Post:
    meakinelli (18th December 2018)
  12. #9
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    ROD,
    FINLY was doing the same thing. I studied up on this, and became aware that many things can and will lead to the same problem. I have now done all wheel bearins and swivel hub bearings and have no "death wobble". Swivel hub bearings are what many refer to as "king pin". All other bushes etc if worn exagerate the problem
    Tim
  13. #10
    Dec 2018
    Italy
    yes mate, same problems on my rig too. was quite frightening the first time it happened. will now either change the parts or power through it. Second option more fun!
