Results 1 to 10 of 19
Thread: Replacing GQ Rear Sliding Window Frames
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Howdy
    how hard is it to swap these yourself? Mine are somewhat dated, and happy to get some new frames, but have never swapped them on any car before, so before I launch into it with my trusty hammer, just wanted to know of any pitfalls.
    Thanks a million in advance.
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    61 Post(s)
    Scotty, I've got no idea but when you launch into it with a hammer and then work out how to do it can you let the rest of us know mate
    PS photos mate, don't forget the photos....lololol
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
    Oct 2010
    Quote Originally Posted by The Dogman View Post
    Well, its sorted then ... hammer out, frames on order, and let's just see what comes of it!!!! Oh ... and you'll have photos my furry little friend ... I'm not ashamed of my cock ups!!! lololol ...
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    if you cock up, just cut the back off and turn it into a 4 door + tray. Then pretend thats what you meant 2 do in the first place *L*
    Oct 2010
    Quote Originally Posted by toddrhind View Post
    but the toolbox will get wet!! I didn't weather proof the b@stard!!! lololol ...
    Oct 2010
    But seriously though ... anyone got any tips/tricks to assist? I'm hurting here people!!! lolol ..
  8. #7
    Perth WA
    61 Post(s)
    This is all that I could find here mate: http://www.nissanpatrol.com.au/forum...window-rubbers
  9. #8
    I've never done it myself but it looks like you just start by pushing on one corner of the window from the inside while releasing the "U" shaped rubber surround from the body if that makes sense. Work your way around but have someone on the outside to catch the window.
    To fit the new window, put a length of about 4mm diameter rope in the "U" of the rubber surround, wrap it right around so both ends finish is the same corner. Put the window up in position on the outside and starting from the corner where the ends are, start pulling one end of the rope to pull the rubber to the inside of the frame (body). Work slowly and keep pressure on the window from the outside.
    I've never done it myself but I've seen it done.
    Tony
  10. The Following User Says Thank You to YNOT For This Useful Post:
    Bigrig (12th December 2010)
  11. #9
    Oct 2010
    Thanks mate - trying to get some information on the process of removal and the proper sealant etc to use when putting back in ... happy to do it, just want to make sure I do it good and proper like!! No doubt there will be the usual concealed rust spots behind them, so will hit those whilst I have the frames out also ...
  12. #10
    Oct 2010
    Quote Originally Posted by YNOT View Post
    Tony
    Thanks mate - I'm going to give it a go ... will order the frames this week, and let's see what damage I can do!!! lol
