28th December 2011, 03:47 PM
Banned
New Coil - Tachometer Jumpy affecting TCU
Ok kids, here goes. Put a new Crane Cams high performance coil in the truck and subsequently, the tacho is now all the shop. As per other posts, it appears the Transmission Control Unit relies on the tacho feed in 'some' way for use of the torque converter (apparently and ohm or two either way of incorrect reading, it won't lock up - which mine now isn't). I took advice from a range of people an ended up going today and buying a new coil with inbuilt resistor to try and reduce the 'feedback' through the wiring and hopefully resolve the issue. Nope - still does the same thing. I swapped the dizzy module also, but it should have no affect at all.
Sooooo ... can anybody offer suggestion of what needs to happen? I've got a mechanical Scorcher dizzy that was sort of ok with the original coil (it was a bit jumpy also but the TC was working), and apart from that, nothing has changed - new valve body should have nothing to do it as it went in after the coil and the TC not locking up problem.
Thoughts?? Pleeeeaaase!!! Now I've tried 2 different coils (tried an EB falcon V8 coil also with the same effect).
Would like my tacho working again properly, but moreso does anyone understand how it affects the TCU as I would prefer to have the TC working again even more so.
Thanks a million in advance one and all ...
Not overly keen to drive another 2400klms down to Victoria and back with it in its current condition.
28th December 2011 03:47 PM
28th December 2011, 05:36 PM
I was just speaking with Scotty.
I think the problem might be the resistance of his replacement coils, does anyone have the workshop manual for a 1995 onwards model GQ that can look up the resistance value of the coil for us? or has one and can measure the value of their coil?
Thanks Rodney
28th December 2011, 05:43 PM
Yendor
Thanks Rodney
If thats the issue then why was it having the same issue on the STD coil?
28th December 2011, 05:52 PM
28th December 2011, 05:53 PM
Rotaredom
patch697
agree with Paul on this one
28th December 2011, 05:55 PM
patch697
The tacho and TC problem only started after he replaced the coil.
28th December 2011, 05:56 PM
He is not currently running a standard coil.
28th December 2011, 06:00 PM
Rotaredom
Yendor
Bigrig
I've got a mechanical Scorcher dizzy that was sort of ok with the original coil (it was a bit jumpy also but the TC was working).
Ok the TC was locking with original coil but sounds like there where problems 2 begin with
28th December 2011, 06:01 PM
.4 to 2 ohms Primary & 6k to 16k ohms secondary
28th December 2011, 06:03 PM
Rotaredom
Scotty, I assume the tacho you are talking about is the Rev Tacho?
Is it just the Tacho doing crazy things or is the the revs of the motor itself?
