23rd December 2011, 02:24 PM
GQ carpet and door pannels??
where can you buy new carpet and door pannels for my GQ?
cheers
Ben
Fully rebuilt and bored out 40 thou each cylinder, GQ RD28t @ 13PSI and over fueled.
23rd December 2011 02:24 PM
23rd December 2011, 05:58 PM
Dribble Master
I've seen them up on ebay mate, there's also a couple of vendors on here who may be able to help........... Nissbits and Patrolapart
23rd December 2011, 08:34 PM
http://www.trufitcarpets.com.au/ is where I bought mine from ... maybe not all that useful since they're in Melbourne.
I have also purchased the Vinyl Flooring from them. They have a Black and Grey. The Black is slightly thinner but stronger than the Grey and very reasonably priced. (I bought the Black). You can ask for samples to be sent to your address to help you decide.
11th January 2012, 12:44 AM
Hi there,
Since you guys are talking about Door Panels, could someone tell me if there are any hidden clips/screws/funny fasteners when taking off the Door Panels. I have to fix the mountings for the bottom hinge in the door as the door has dropped and the panel seems to want to stay put.. Is this a common problem?
Anyway, any help would be appreciated.
Regards,
Stephen.
11th January 2012, 04:31 AM
Patrol Guru
tinkerer
Hi there,
Regards,
Stephen.
Gday mate,
Few screws on the handle (depends on what type of panel you have) and plastic clips all around the panel. You just need to pry the panel off gently with your hand or a flat screw driver..
The Following User Says Thank You to Ade For This Useful Post:
tinkerer (17th January 2012)
11th January 2012, 06:42 AM
Advanced
There is a specail tool for this and only a few dollars from any brand car dealer (or supercheap ) ask for a window winder circlip remover its a double ended blade thing that slides under the clips so you can gently lever em out and not break em as ya normally do with a screwdriver and its only a few dollars
Only a dog understands why bikers ride bikes
The Following User Says Thank You to cokeholic For This Useful Post:
11th January 2012, 09:21 AM
Banned
tinkerer
Hi there,
Regards,
Stephen.
Depending on the door, there is a screw inside the bottom of the handgrip under a covering plug - undo that one to take the handgrip out and theres two screws behind it holding it in place. Remove them and the one on the opening handle/mechanism and the clips should come away easily by prying off one by one (even with your hands).
Just done this myself to fix the electric motor for the front passenger window - as said, this will depend on the model.
Good luck with it mate!!
The Following User Says Thank You to Bigrig For This Useful Post:
17th January 2012, 12:49 AM
Hi guys,
Thanks to everyone for the help.. Job done, and not too hard to do either. I have to say, the old Patrol is fairly easy to work at, I would even say enjoyable...
Stephen..
19th January 2012, 01:46 PM
very easy job (Door Panels) especially if the Troll is older, (or if it has had speakers replaced already, should come out easy
25th January 2012, 01:21 PM
Hi mate, I just saw an add for Tru Fit so gave em a call, they do vinyl or plush pile carpet moulded sections for patrols. The vinyl is a bit thicker than standard: $220 includes front and rear section. The plush pile is around$180 (I think). $19 aus wide delivery. 1800335896. They also do that noise reduction stuff too.
Hello from Under Down Under!
