Andy, I'd steer clear of having the chassis "cupped" as it could trap moisture/mud and assist corrosion. My sliders are bolted to the chassis with two 8mm-thick plates both sides. Two high tension bolts top and bottom. It is super strong and I can jack both wheels off the ground with no deflection at all. If you can keep your chassis open to the air I think you should do it that way.
What diameter bolts did you use? I am just thinking of the space between the top of chassis rail and the floor. I have a short wheel base GQ and they way you have used the bolts instead of making a cup is a great idea.
