Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Pyro and boost Gauge.. Where to put them?
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    The only decent place to put a Pyro and Boost is a Pillar Pod to be honest. You want to see the Pyro more than yo want to see the bloody speedo mate, Dont dump it half way down your dash as it will become less relevant and it might just save you car one day.
    I have mine in the GQ mounted in the middle and it is good but i have a double pillar Pod in the GUIV and it is perfect.
    Yupx3..agreed with you boss. At least pyrometer should be mounted on the dash, best side to side with boost on the pillar.
    330 Post(s)
    Quote Originally Posted by Ade View Post
    This is how I mounted my gauges, an ally plate with counter sunk holes. Routed the wires through a hole right behind the windshield. There are 4 or 5 of the holes with round cover that can easily be pried off.
    Yeah Ade i have mine in the exactly the same place as you have and pretty well same design but made a mount above the dash mat for 4 gauges.
    In order from driver to left is Boost closest, then Pyro, Water temp, Oil Pressure. Works great but you have to make the decision to turn your head to veiw them, mounted down low you'd have to physically move your head and body to read them.
    The Pillar Pod is as simple as checking the speedo, flick of an eye.
  4. #13
    330 Post(s)
    some pics of them in them in the GQ
    and a pretty crappy shot driving on the freeway
  5. #14
    Advanced gbab01's Avatar
    Adelaide
    Hi. I have mine on a pod in the centre of the dash but would say the pillar pod is the go. I used this as a temporary measure as I know my wife would complain as soon as she got in the car (which she did) and after a short time will have no complaints about me buying a pillar pod. Sneaky. I ran the wires and the tube out the back of the pod and then along the gap between the dash and the windscreen, towards the drivers door, down and then through the fire wall access point near the drivers foot. Will need to remove the drivers side door pillar cover and the drivers side kick plate cover to get to do this. This prevented my drilling any holes in the dash (the pod just sits there at the moment on dash mat - could use seme velcro maybe). In line with my master plan, when I get the pillar pod the tube and wires will run up in to that and will not be seen! You could have the centre pod permanent if you want as the wires etc. are really are not that noticeable anyway. Bets to think first before grabbing the drill I reckon.
  6. #15
    I will be ordering this one : http://mcnallyelectronics.com/index.htm as soon as I figrue out whether my 2001 GUII dash lights can be changed to blue. Then I order this one and mount it right in between the speedo and tacho.
