26th November 2011, 11:25 AM
Gu 2.8 aircon bearing
Just replaced the noisy bearing on my a/c compressor i decided to leave where it was and see if it could be done as most forum sites recommend to unbolt and bring to top of engine bay its a fairly simple job leaving it mounted just awkward took me about 4hrs all up for anyone who needs the replacement bearing number for this model its 83A694CS30-J it also suits the following models hope this helps (i tried to up load some pics of changing the bearing but uploading kept failing will upload when i can work it out)
Clutch bearing for:
◦Sanden SD505
◦Sanden 507
◦Sanden 5H09
◦Sanden 5H11
◦Sanden SD709
◦Sanden SD7H13
◦Sanden SD7H15
◦Zexel DCW17D
◦Tama TM-Series
Theres only one thing tougher than my truck............. YES DEAR GOING TO DO THE LAWNS NOW
WARNING: Towballs used for recoveries,can and do kill people and damage property
The Following User Says Thank You to patrol2.8 For This Useful Post:
the ferret (28th November 2011)
26th November 2011 11:25 AM
27th November 2011, 08:53 PM
went for a drive today and have found since changing the bearing aircon is now on permanantly any ideas where ive gone wrong
27th November 2011, 08:59 PM
When you removed the clutch plate, was there any shims? did they go back in?
27th November 2011, 09:16 PM
I didnt see any when i removed it will look in the box i put all the bits in case they fell out and i missed them
27th November 2011, 09:27 PM
just looked at the manual will be the shim had a washer type thing in the box thought it was left over from another job that i did will replace tomorrow what a dunce
27th November 2011, 09:32 PM
Yes the shim is just a washer that slides over the end of the compressor shaft and sits on the lip on the inside of the clutch plate, so it spaces the clutch plate away from the pulley.
There is normally at least one shim (it depends how much clearance there was when the compressor was manufactured).
If you disconnect the wiring at the compressor does the clutch stay engaged? (engine running).
27th November 2011, 09:58 PM
aircon was working normaly before i changed the bearing just the bearing that was buggerd when i started car after i changed it i just hit the aircon switch and heard it click in ran it for a few minutes to see ifall was ok then just shut it down that was friday today was the first day that i have driven it since fixing it will put the shim in tomorrow 99.9% sure thats the problem
28th November 2011, 08:03 PM
28th November 2011, 09:01 PM
Hardcore
Yendor
Ha ha , Yer on the ball mate fer sure.
Cheers, the ferret.
29th November 2011, 07:24 PM
One thing i did notice aircon actually runs coler without the shim in
