Results 1 to 7 of 7
Thread: Which type of performance muffler?
    Patrol Guru motorculture's Avatar
    Sydney, Australia
    A popular question that we normally get from customers and a popular topic among car forums is “Which flows better, oval or cannon mufflers?”
    A mufflers main job is designed to muffle or eliminate sound waves generated from your engine. Mufflers may look the same on the outside but not all mufflers are created equal and can use different methods or sometimes multiple combinations (Chambered, Absorption, Reverse and Twin passes) to reduce noise levels.
    Chambered muffler:
    Chamber muffler designs can vary however the basic concept is the same. Above is an example of a factory chambered muffler design. First thing you notice is that there are 2 chambers; a main flow chamber and a resonating chamber. In the main flow chamber exhaust gasses flow through a perforated tube before exiting through to the outlet tube. While the Resonating chamber (the larger chamber) is where the sound cancellation occurs. In the resonating chamber, a specific volume of air and length is calculated to produce a wave to cancel out a certain frequency of sound. Thus reducing noise and drone level. It’s good news then for car manufactures who have strict noise levels to meet or for people who require little to low noise level.
    Good for noise restriction, bad for flow since it can create unwanted back pressure in the main flow chamber.
    Absorption/Straight-through Mufflers
    Example of a straight through muffler. Please note this is not an Xforce muffler.
    Absorption straight through mufflers consist of a single perforated tube and have virtually no restrictions and offers the most flow. A combination of stainless steel cloth/wool and fiberglass packing is used to fill in the void between the perforated tube and muffler canister, the packing helps dissipate and absorb sound waves (mainly high frequency sound). Absorption straight through type mufflers are mostly your cannon type mufflers, but can also be made in a oval type too. The easiest way to tell is to hold up the muffler in question and look through one side of it. If you can see the other side then you have a straight through muffler!
    Important factors that will determine the sound characteristics:
    Muffler size: The larger or longer the muffler body/canister is, the better sound dampening effect it will have. Check sizing for a quieter and deeper exhaust note.
    Inlet and center tube size: The larger the inlet and tube sizes are, the higher sound level will be, (normally the outlet is the same size with inlet and center tube).
    Muffler packing: the material and density of the muffler packing are also crucial for the sound characteristics.
    XFORCE chooses to use the straight-through absorption design for our sports mufflers, Testing has shown that they produce maximum power gain and overall a better sounding exhaust. For our mufflers we only use the best quality material for muffler packing.First layer is a heat resistant stainless steel wool used to insulate the high temperatures generated by high flowing exhaust gases, and for best sound dampening effect we densely packed the second layer with high-grade fiber glass. XFORCE also offers many variety of muffler sizes to suit all sorts of project cars. To check them out, Click Here.
    Example of a straight through oval muffler. See how you can see straight through the other side. This is great for flow!
    A Reverse Flow muffler.
    A reverse flow or “turbo” muffler takes the exhaust gases on an S-shaped path through the muffler. The exhaust gases travels to one end of the muffler, is turned 180 degrees and heads back to the first end. From there it is again turned 180 degrees before it passes through the outlet. Great for producing sound cancellation waves and reducing noise, but the increase in backpressure and unnatural exhaust flow ultimately means that a straight through muffler will easily out flow this design.
    A combination of Chambered + reverse flow type muffler+absorption. This muffler would almost create no noise. You can see that the exhaust gases has to flow through an absorption chamber three times before exiting, and a resonating chamber is included to cancel out any remaining sound waves that are missed. By looking at the arrows, flow would be compromised in the last and middle chamber. Lots of back pressure!
    Twin loop muffler
    In a twin loop muffler, exhaust gases flow in a natural spiral shape path through the muffler twice before exiting the tail pipe. It has all the advantages of the absorption straight through muffler and none of the reverse. A twin loop is effectively two straight through mufflers compacted in one.
    The twin loop is great for vehicles with limited space but requires maximum HP and low noise level. They are popular choices for many four cylinder naturally aspirated cars such as Honda Civic, Integra.
    Varex Muffler
    A VAREX muffler is a combination of a straight through and reverse type muffler. When the valve is shut closed exhaust gases are redirected away from the main flow path and through a smaller opening before exiting. Sound waves are reflected and cancel out any sound waves of the same frequency. Any escaping sound waves are dissipated and absorbed by the stainless steel wool and fiberglass packing. When the valve is opened it is essentially an absorption Straight-through Muffler providing maximum flow.
    To see the full range of high performance Xforce mufflers and Adjustable Varex Mufflers visit : http://www.xforce.com.au
    Please note: All pictures and images belong to their respective owners.
    Automotive social media http://motorculture.com.au or call us on 02 9418 9008
    For some daily car culture check out http://zengarage.com.au/
  2. The Following User Says Thank You to motorculture For This Useful Post:
    Silver (26th November 2011)
    Legendary
    An interesting but completely useless side note about mufflers, I remember reading when HSV developed the 215kw 355 stroker V8 engine back in the VR Commodore days I think it was, they spent a great deal of time trying to get the right exhaust note. In the end it came down to switching from round holes in the perforated muffler tube, to square holes.
    Well I did warn you it was a useless side note!!!
    Tony
  5. The Following 4 Users Say Thank You to YNOT For This Useful Post:
    Ben-e-boy (25th November 2011), motorculture (28th November 2011), MudRunnerTD (24th November 2011), Silver (26th November 2011)
  6. #3
    But very interesting none the less mate lol
  7. #4
    22 Post(s)
    My perfomance muffler sits in the corner of the garage haha
    96 GQ coil/Cab
    08 G6eT
  8. #5
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Stop laying the one liners up for me!!! lmao
    Something along the lines of ... "that explains the lack of performance elsewhere"!!!!
    Lordy, I'm giggling!!!!
  9. #6
    RIP - valued member and true gentleman of this forum that will be missed by many! Silver's Avatar
    Feb 2011
    Brisvegas
    my idea of a performance muffler is one that will cope with ignition off, pump throttle, ignition on, while going down a hill in gear :-)
    Yeah, yeah, juvenile. but I have made a muffler that looked exactly like that picture of the double reverse flow jobbie :-) except that a bit of it jumped out onto the road in all the excitement.
    In my defence, I knew the likely consequences of my actions - a few booms and then due to one pump too many, a boom and a crash sound, and, the existing exhaust was crap with a drone that would out do muddies at 105 - 115 kph. The new system is nice - no drone, and nice note. Loverly wife did customise the end of the tailpipe however - they didn't tuck it up enough. Must go back and speak to them about that :-)
  10. #7
    Dec 2012
    good to know guys, thanks
