Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: altrnater sleeping
    Sep 2011
    altrnater sleeping
    hello can anybodey help with alternater truble. parked up 5 weeks ago with leekey rad, now fixed rad just to fined alternater not charging.
    It has 1 x thick white wire which goes to 24v battery turminel i assume is the charging power out
    1x thin white/red tracer wire (which i think goes to the battery warning lite. The battery warning lite goes out when i unplug it)
    1x medium white wire which goes to 24v battery turminel which i assume is the power in
    Ive got 24v on the white/red wire and 24v on the thick white wire no change with reving engine. no differance if i turn lites on, slite v drop as exspected.
    can anybodey id make of alternater .any advice for testing internal conponents of alternater. ( the money pot is dry for macanics so will have to fix myself, hear we go again)cheers for any help
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    One of the electrically minded lads will be along to assist no doubt mate - hang tight.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The wiring you have described it sounds like the alternator has an internal regulator. I thought the MKs had an external regulator???. Is there a square box mounted on the guard near the alternator with about 6 to 8 wires going to it?.
    Does the warning light come on when the ignition is turn on and then go off when the engine is running?
    What voltage are you seeing at the battery and back of the alternator at a fast idle?
    Sep 2011
    hello, no box of wires. bothe whites are live at all times as should be according to manuel. white with red trace goes to charge lite then according to manuel recives power on ignition. lite coomes on with ignition and stays on. voltge at bat is 24v. voltge going in to alternater is 24v. voltage cooming out is 24v. same when running at higer reves , no change.
  6. #5
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I would remove the alternator, strip it down and inspect. It could be something simple like sticking brushes.
    Are there any signs of an oil leak from the bottom of the alternator?
    It looks like a hitachi alternator.
  7. #6
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    MK have internal regulators. Hitachi alternators is correct. New one approx $380.00 for 12v one. I found it hard to get just regulator only.
    Where R U Robus?
    Tim
  8. #7
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by robus1 View Post
    I don't spose not having a belt on it would be the problem lol.
    Cheers, the ferret.
  9. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by the ferret View Post
    Cheers, the ferret.
    I thought you were out hunting drop bears.........
  10. #9
    Sep 2010
    on the coast W.A.
    Quote Originally Posted by Yendor View Post
    Wait'n fer a full moon Rodney, and I know where you've been!! lol
    Cheers, the ferret.
  11. #10
    Sep 2011
    has got belt on, its got twin pulley for some reason. striped it down, bushes, berings all ok. have taken it to shop and they rekon diods gone. will be looking into manuel on servicing alternaters and starter moters. seems to be a lot of money to be made in replacing a diode. cheers for all youre help
