21st November 2011, 09:04 PM
about to grease my nipples, what grease?
So what can i say but im about to grease my nipples what grease do i need, lithiumv multi? oh i am talking about the ones under my troll not my... get your minds out of the gutter. I did a quick search but did not turn up anything.
21st November 2011 09:04 PM
21st November 2011, 10:46 PM
23rd November 2011, 08:24 PM
I don't think the type of grease is so important, it's more important to do this often, at least once a year!
23rd November 2011, 10:59 PM
A good multi purpose grease is fine for suspension, but EPL2 is a better choice, as you can get it to push through a tight joint with a good grease gun. Multi purpose doesn't handle to Extreme Pressure sometimes requied.
Remember to only Use HTB (High Temperature Bearing) grease for all bearings in wheels and swivel hubs.
Or the new LMX is a good High temp bearing grease and moderate pressure grease all in one. It is the perfect Automotive grease to have in your shed.
Tim
The Following User Says Thank You to Finly Owner For This Useful Post:
23rd November 2011, 11:11 PM
Seems like someone knows a bit more than me on htis topic... But its still important to do this often
23rd November 2011, 11:42 PM
And if doing suspension bushes, use rubber grease on them to help them slip in place.
Tim
5th December 2011, 12:34 AM
Thanks guys. How many nipples are there on the swb gq's?
5th December 2011, 09:17 AM
7 on the prop shafts, and about 7 on the steering. remember to wipe the dirt off the nipples before you pump the grease in as you dont wont this grit going through the joint
The Following User Says Thank You to bobbrumby For This Useful Post:
5th December 2011, 11:11 AM
bobbrumby
Cheers mate. Looks like I missed a couple.
5th December 2011, 04:45 PM
i am pretty sure the swb would have the same double cardinal joint for the front prop that has 3 u joints in close proximaty
