18th February 2012, 02:41 PM
#11
I dunno, in my experience having water tanks outside the cabin means the water gets way too hot. Im buying the offroad systems water tank that goes in between the rear seats and the half height cargo barrier. I'd think folding up a similar design from stainless sheet for those handy in that stuff would be better imho.
18th February 2012 02:41 PM
19th February 2012, 08:35 AM
#12
I like the idea of a tank between the rear seet also. I was thinking of the PVC pipe in a stack.
What would you be if you were attached to another object by an incline plane wrapped helically around an axis?
Screwed.
19th February 2012, 01:00 PM
#13
nullack
Very nice, I like it, put out on my wish list
19th February 2012, 11:38 PM
#14
The bloke I bought my GQ off dodgied up a pvc pipe like that to fin in the roof basket, looks pretty agricultural but does the trick, good for a warm shower at least!
3rd March 2012, 01:16 PM
#15
Remember only food grade storage container for drinking water.
that includes the hoses and fittings.
don't make your self sick.
cheers
4th March 2012, 10:44 AM
#16
Great idea on the cheap and use of wasted space. Like Robo said take care of the materials used, silicon is probably not the best choice to seal the pvc. There are food grade pvc sealents available.
3rd April 2012, 07:09 PM
#17
4th April 2012, 02:04 AM
#18
Careful with PVC been told its not food grade and nasties can leach into the water. Ok for cleaning and such but possibly not best for consumption.
I'll follow a wise old mans take of this water business. "why bring water when beer will do"
6th April 2012, 06:19 AM
#19
Got me thinking about a HDPE (poly) pipe run around the inside of a roof rack with a tap on one end might make a good solar shower system, Poly is cheap and you can get all the compression fittings from hardware or agricultural places, being black pipe it will soak up the heat from the sun yet its very durable and won't perish in the sun. It will put up with alot of abuse, we run 100psi air through it at work no problems and thats with normal compression (plasson) fittings.
If you going through hell...Keep going
GQ wagon locked - lifted - 33's, 02 SS ute, XB coupe 460bb, KTM530
10th May 2012, 05:41 PM
#20
Patrol Guru
Not a bad use of otherwise useless space, I had a couple of lengths like that under the tray of my old ute, but used them more for storage than water. Up north I've seen quite a few systems similar, if its on a ute, Ive seen the PVC pipes following the contours of the tray headboard used as water tanks.
