Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 5th gear low range manual, what speed should I get at 3000rpm? ?
    43 Post(s)
    As the title says I'm just wondering what speed I should be going at 3000rpm in 5th gear low range??
    North brissy
    Not very fast.
    Doesnt nissan recommend a speed you shouldn't exceed in low range. Something like 50 or 70 kmh
    Cant say Ive ever been in low 5th, so no idea
    guessing maybe 40 kph maybe more
    462 Post(s)
    Yeah. If your in 5th low you should be in maybe chasing gears in high range i reckon. Too much unnecessary stress on 5th when its not needed.
    But i would guess around 50ks.
    Jan 2014
    Shepparton VIC
    Wait... what...? 5th on low range...?
    Is that 5th on low range or 5th on 4WD high range?
    I doubt that you will be ever in a situation where you are looking for anything more than 2nd gear in a low range - and again I may be wrong to assume so.
    Cheers,
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
    .......... TPC's Avatar
    63 Post(s)
    As others have said, have never been in 5th low and would not try.
  8. #7
    330 Post(s)
    Wow!! I have been in 5th Low Heaps of times!! I reckon your good for 50 or a little faster Kallen.
    Low Range in Sand can be far less stressful on the gearbox in all gears so to get to 5th in Low is not unreasonable or surprising when your running down the beach. Your likely not to be there for an extended period as stopping and grabbing HiRange is reasonable but some of the beaches in SA are long enough to find 5th but short enough to not bother with HiRange. IMO.
    Your Gear box has 5 gears for a Reason and splits All 5
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (11th January 2016), Rossco (11th January 2016)
  10. #8
    22 Post(s)
    about 30 for me Im guessing. the tcase starts screaming just above 20km so I dont go any faster
    96 GQ coil/Cab
    08 G6eT
  11. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    growler2058 (11th January 2016)
  12. #9
    330 Post(s)
    Yes yours was very restricted hey! Allen are you looking to fit up those reduction gears you have into the GU? it will certainly drop your speed somewhat. Bene, you have 85% though yeah? Kallen only has 24% i think?
  13. #10
    Seeing as you basically double your horse power from selecting low range
    and 5th being a very weak link in a gearbox, I would recommend High range.
    but you are asking out of curiousity I gather, as for those reduction gears
    are there any 63% ones still left seemed to be the perfect reduction lol
