9th November 2011, 07:03 AM
Administrator
Nut size for Exhaust manifold studs - TD42
I'm being lazy but hoping someone might know the nut size for the exhaust manifold studs on a TD42?
I am not sure if It's an M10 x 1.25 or M10 x 1.5???
Cheers for any help!
9th November 2011 07:03 AM
1st December 2011, 11:03 AM
just be careful as a lot of the older cars have had the front and rear studs on cylinders 1 and 6 drilled out and replaced with large stud bolts as they have been stripped form over tightening warped manifolds I learn't the hard way after putting copper gasket paste on the turbo manifold and then realizing I had to drill it out and the gasket.
1st December 2011, 03:35 PM
I just replaced four of mine that sheared off. I can't remember the block thread pitch but I'm sure it was M10x1.5 . I couldn't find studs to match both inner/outer so the outside thread pitch was definitely M10x1.25. I just ended up using different nuts on the new ones.
1st December 2011, 03:50 PM
Jesse, there is a metric nut, bolt and pin distributor in Surrey.
1st December 2011, 04:18 PM
jfarsang
Affirmative on the outside thread Andy..M10x1.25. Just snapped one on mine yesterday on an attemp to mount the pyro probe to the manifold..very niceeeeeee
