12th November 2011, 11:07 PM
#11
YNOT
The hubs themselves are interchangable between MK (assume MQ is the same?) and GQ/GU. There is a difference in the drive dogs that attach to the outer axle spline, MK has 29 splines, GQ/GU has 31 splines and is slightly bigger diameter. The outside of the drive dog is the same (28 tooth). The circlip that holds the drive dog in place is also slightly bigger diameter on GQ/GU.
Tony
Well at least we know now. Gunna throw a thread on the club forum to?
Tim
12th November 2011 11:07 PM
4th January 2012, 08:46 AM
#12
I used to have super winch hubs in mq (w260 model) working well even in worst conditions, now I have AVM ( red version-should be stronger that normal ver.). Looks same as super winch -works well. one advice, after asembly, put something into screw holes ( those small ones in aluminum cover), some dense grease. those screws likes to get rusty and than hard to unscrew.
