18th November 2011, 07:40 PM
-03 Toyota LandCruiser 3.0 GX Arctic Truck
-91 Nissan Patrol 2.8 tdi 38"
If You're Gonna Be Dumb,
You Gotta Be Tough!
18th November 2011 07:40 PM
19th November 2011, 01:13 AM
tackling them on Sat with a friend. hopefully get them all done ready for a shake down test on Sun on some of the local beaches and dunes.
2005 GU 3.0L ST
Cooper tyres, Alloy B'Bar, Safari Snorkel, 3" Exhaust, Rhino Racks, Dual Batt, NADS
and a very big wishlist in the glove box...
19th November 2011, 07:50 AM
satyx
Interesting GRA.GU ..... was the LHS side a better fit or something? I would have thought they would be the same.
Yeah, I'm curious about this too. What happened to the original RH handle?
I received my Autron gauges & pillar pod during the week. Now just have to find someone to weld the bungs in. I've got one guy who will do it but charges by the hour so a bit tentative to line him up.
I've had a look at the heat shield & I think that with an air ratchet I should be able to get to most of the bolts - does anyone know if are there any hiding out of sight?
2011 CRD with a bunch of stuff bolted on
20th November 2011, 12:41 PM
i just put the new one over the old but if you have a new pod you have to cut the pod base
i checked out both ways but over the old cover i think is a nicer fit
27th November 2011, 07:43 AM
Sorry Stevo and Satyx, I didn't see your questions until now.
No, there is no advantage to changing handles - they are identical. It was just that mine, being a DX, did not have a RH handle and fitting one was the most effective way to hold the pillar pod on. Cheers fellas.
27th November 2011, 09:58 AM
Thanks GRA. Yep, I installed mine yesterday, didn't use the original underneath, just used the handle to keep it in place. I put some foam in behind to keep things nice and tight.
2nd December 2011, 01:24 AM
#17
ok that explains it.
cheers GRA.GU
2005 GU 3.0L ST
13th January 2012, 08:55 PM
#18
Did you have to modify the pod to fit as suggested above a couple posts. ? Thanks
14th January 2012, 12:24 AM
#19
bastardo
Yes I had to trim off a small portion on the base of the pod. will throw up some pics soon of the job half finished. Has been a very busy few months.
2005 GU 3.0L ST
