Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: dumbie tail lights on a gu
    Advanced satyx's Avatar
    Aug 2011
    Rockhampton, Central Queensland
    Quote Originally Posted by hekarewe View Post
    i replaced my dummy lights with working lights from www.carsrus.com.au on the sunshine coast cost me including gst and frieght $144.00 approx only issue is when wiring you will need to run a lume from the left side for some of the lights in the right hand unit. left hand unit is plug n play i ran wiring across from the left under the door sil to the right to get everything working on the right once done looks great and very bright
    hope this helps
    Those look good. Do the kits come with regular bulbs? Would it possible to adapt them easily to LED?
    2005 GU 3.0L ST
    Cooper tyres, Alloy B'Bar, Safari Snorkel, 3" Exhaust, Rhino Racks, Dual Batt, NADS
    and a very big wishlist in the glove box...
    Aug 2011
    Kellyville, Sydney
    I drilled my factory lights to take bulb holders, ran the loom for the reverse light across the rear sill, and tapped the lower lights for power. Total cost as about $50-60 and ~2 hours of drilling and filing to make the bulb holders fit. The bulb holders and wiring is occasionally sold as kit on eBay.
    I then fitted all the lights with LEDs to reduce the current draw, otherwise you would need to increase the fuse amperage due to the extra load of the extra incandescent bulbs.
  4. #13
    Patrol Freak hekarewe's Avatar
    Feb 2011
    springfield lakes
    Quote Originally Posted by satyx View Post
    the one i got come complete with wireing and globes dont think they can be converted but anything is possible
  5. #14
    How's the serenity boots's Avatar
    Sep 2011
    satyx , mine were not regular type bulbs / globes . they are a '' big size '' wedge type globe . pretty sure from memory the reverse light- left side original is the same . I had not seen this size wedge type globe/s until I changed mine . but so far so good .
  6. #15
    Beginner Arwon's Avatar
    Apr 2011
    Mine off eBay, $135 delivered to the door. Fitted well and looks like they were meant to be there.
    Sent from my iPhone. Please excuse the spelling.
  7. #16
    Aug 2011
    hmmm ....... i might add these to my christmas wish list to Santa....LOL
    2005 GU 3.0L ST
  8. #17
    Advanced Skull's Avatar
    Nov 2011
    Currently Rockingham WA
    The reason that patrol and many other makes of car in Oz don't have these working is ADR compliancy. It is deemed by the guys on the big bucks that all lights on the rear of the vehichle must be visable from 45 deg each side of the cars axis. With the spare wheel fitted to the back door the drivers side light is obscured from 30 deg. The ARAB release cars had them working. It is NOT illeagle to fit working replacements. I beleive it is madness not as these are the lights which the guy following you has clear in his field of vission. Big red brake light looking thing, not the lil reflector looking thing in the bumper. I think that even though not really ADR compliant it should still function. The only reason not to do this mod would be if you had twin wheel carrier which would obscure this anyway. Easy mod. Pull em out, buy some push in lamp holders, drill with spade bit to receive the holders, wire up parrallel to other lights. Done. One tip use LED bulbs as they will not increase the current and blow fuses like fillament lamps will.
  9. #18
    Aug 2019
    Hi there. I've purchased after market replacements from Sydney as my covers were cracked. as mentioned in your post, they came with the required wiring, but after fitting them, neither indicators or dash flashers work. I've checked all the globes and connections, but to no avail. Tail, stop lamps and revering lights all work. Any suggestions as to where to go from here (other than an auto electrician)?
  10. #19
    Gold Coast
    My ebay replacement lamps have been working for more than 4 years. Basically need to get the wiring correct off the existing lights. Yes, you do need to make a loom to get side to side, but nothing forward of the lights. I love mine
  11. #20
    Jun 2018
    24 Post(s)
    Quote Originally Posted by Dr Gary View Post
    Have you been using the old style incandescent bulbs or newer LED style bulbs?
