Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: HELP!! increase in revs while ideling
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    How long does the idle stay high? Does it return to normal idle after a quick jab of the throttle? If it does then it might have something to do with the auto choke.
    Is it only when you start up or does it rev high after driving for a while?
    Hello from Under Down Under!
    Beginner steelo's Avatar
    Nov 2011
    Hervey Bay
    My rb30 does similar stuff, but when it warms up (time can vary) it runs normal. I've also removed the fuel warmer "net" from the carby (in the poly/plastic plate) but & also widened the spray chamber just at bottom of chamber as the last 2 cyl/plugs didn't seem to be getting the same amount of spray/fuel.
    1991 ST, rb30s motor, 2" susp lift - hd TJM coils & Suspension Stuff "Ultima" shocks, 235/85/16 a/t Kenda tyres
  4. #13
    Sep 2011
    adelaide
    18 Post(s)
    Hi Shaunh.
    There is a small spring between the choke fast idle cam and the carby body which if fitted incorrectly will catch the cam and cause irratic ideling.
  5. #14
    Feb 2012
    you've probably sorted it by now,
    is your hand throttle all the way in? my revs vary when I use that, not quite from 400 to 1800, more 500 to 1000, I'm doubtful that that's the cause, but worth a check. by hand throttle I mean this
    http://www.nissanpatrol.com.au/forum...highlight=lock
  6. #15
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    Sticky throttle cable, loose carby, sticking butterfly in carby, sticky choke mechanism, vacuum leak, faulty PCV .worn butterfly shaft.
    Cheers, the ferret.
  7. #16
    Expert johno90's Avatar
    Moranbah QLD
    revs go up and down at idle = hunting = leak in manifold, easy way to check is get something like t/b cleaner and spray around all contact areas if revs change when spraying at a certain spot theres your leak
  8. #17
    Feb 2012
    Rockhampton QLD
    Might possibly be the carby needing an overhaul, i had this problem in my old 91 GQ nd it fixed the problem, then i converted it to EFI lol
  9. #18
    Hardcore
    central coast nsw
    Get yourself a manual and start checking for something wrong on carby by the specs given.
    I'm leaning towards what pearcey said about the spring, possibly even broken.
    there's something funny going on around this area.
    but it really should be a pain to start if you don't touch the acc pedal to start especially cold starting.
    that's how choke is engaged, you have to push a little to activate auto choke.
    cheers
  10. #19
    Expert HammerBuilder's Avatar
    Lismore, NSW
    So how'd you go shaun with your rev problem is it sorted now or are you still playing? Also check your vacuum hoses for leaks even down to the hose from the rocker cover to the inlet manifold. anyway see how you go & let us know whats happening.
    Cheers Tony
    Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
