29th May 2014, 06:48 PM
#41
Oh again what Threedogs said re exhausts.
There is also Bauedesert that make a good system albeit for the patrol they recommend a 2.75"
What I can recommend is find an exhaust supplier that gives you a mandrel bent system as this gives you a uniformed diameter from front to back.
Get a system that bolts immediately to the back of the turbo dump, not after it.
Get a system that already has an EGT bung welded I to the dump pipe, that way you do not have to then take it somewhere to get it retro fitted after you put it in.
Kindest regards
Graham
Sent from my iPad using Tapatalk HD
29th May 2014 06:48 PM
