10th September 2010, 10:56 AM
#21
myaccount69
3 litres are guttless!
I take you've never seen a Boosted one
Mine has an RB30et in it, from a VL, never had a power problem
Depending on price, i'd buy it, then put the complete Injection and Turbo set up off the VL on it, as long as you get the 4WD cheap, it will work out cheaper than a 4.2, and the extra advantage is there will be more power than a 4.2, with around the same Economy
People are right though, and off boost Tourque is not great, BUT a set of 43% Transfer reduction will fix any of those issues, even running 37's.
About the only differance is the Turbo\NA Head has differant Cam, some say the NA is better in a Boosted 4WD as the Tourqe comes on sooner.
Chris
10th September 2010 10:56 AM
10th September 2010, 09:57 PM
#22
YNOT
This is the RB30 carby mod I was talking about.
Start by removing the air filter from the top of the carby. Then undo the 4 carby base bolts (nuts actually), one of the nuts you will have to lift the carby up a bit to get it right off. The carby can then be moved to one side without having to disconnect anything else. Be careful when you lift the carby and try not to damage the base gaskets.
The bit you need to modify is the heating element in the spacer directly under the carby. Disconnect the wires going to the heating element and carefully remove the spacer. This is what it looks like when you first remove it.
Carefully drill out the pins surrounding the honeycomb element, and push out the element. The can looking thing on the other side just pushes out.
And what you're left with should look like this...
Installation is the reverse of removal.
Tony
another one for YNOT Helpful posts file
