I have a 99 GU RD28 and have a brown relay above some fuses near drivers seat which keeps buzzing when i either turn the key to ON position or when i switch the car off. When i take out the relay i know the engine and glow plug lights turns out on dash.
I've had a look in a few manuals but doesn't seem correct. One book says its ECM relay and another states its Heated Seats.. I know i don't have heated seats and i don't believe that the 2.8GU came out with a computer? Any help would be nice.
I have attached a pic showing the brown colored relay location.
Sorry, i should rephrase drivers seat, its in your standard fuse compartment below steering wheel near bonnet lever.
If it did come with an ECU, then where is it located because i have the entire dash around steering wheel removed at the moment and cant see no computer.
That's very interesting, with my covers all out and taking a look to that corner i do not have a ECU module at all. I do have a tiny little black box but doesn't look like computer module. Also, the fuse compartment has the brown relay as per image where heated seat relay is located but i do not have one to the right of it stating ECCS module as per image above unless the location has been put to the right where heated seat relay sits.
