Results 1 to 10 of 14
Thread: Adjusting GQ Headlights
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I had to loosen the grill so i could get the drivers side headlight out. i Mustve "nudged" it a bit when i bent the bar lol.
    Anyone know a good way of adjusting the lights without using trial and error? Like in a workshop the have a board and you park a certain distance away and it has marks on it to point the lights at......
    Hello from Under Down Under!
    Aug 2011
    North West Tas
    56 Post(s)
    Feb 2011
    Shed
    45 Post(s)
    Yeah if ya get flashed by on oncoming traffic when yer on low it's too high ;-)
    Tap, Tap.......Who's there?
  5. The Following User Says Thank You to growler2058 For This Useful Post:
    taslucas (28th July 2012)
    Aug 2011
    North West Tas
    56 Post(s)
    so trial and error then.....lol or im on their side of the road!
    SUCH IS LIFE Maxhead's Avatar
    ACT
    If one light is ok then drive up to a brick wall and adjust the other as the brick gives you a few lines to work off. If both are out then goto growlers post... Hahahahah
    ..........on the move
    ________________________
    ______ 2017 D-Max _______
  8. The Following User Says Thank You to Maxhead For This Useful Post:
  9. #6
    Aug 2011
    North West Tas
    56 Post(s)
    lol i thought you were going to say use the brick wall to "adjust" the grill back into the right spot! It was a tree that adjusted it in the first place lmao.
  10. #7
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    HEADLAMP
    Aiming Adjustment
    When performing headlamp aiming adjustment, use an aiming
    machine, aiming wall screen or headlamp tester. For operating
    instructions of any aimer, it should be in good repair, calibrated
    and used according to respective operation manuals supplied
    with the unit.
    If any aimer is not available, aiming adjustment can be done as
    follows:
    For details, refer to the regulations in your own country.
    CAUTION:
    a. Keep all tires inflated to correct pressures.
    b. Place vehicle and tester on one and same flat surface.
    c. See that there is no load in vehicle (coolant, engine oil filled
    up to correct level and full fuel tank) other than the driver
    (or equivalent weight placed in driver's position).
    & = ACCEPTABLE RANGE
    LOW BEAM
    1. Turn headlamp low beam on.
    2. Use adjusting screws to perform aiming adjustment. ,
    First tighten the adjust screw all the way and then make
    adjustment by loosening the screw.
    a. Adjust headlamps so that main axis of light is parallel to
    center line of body and is aligned with point P shown in
    illustration.
    b. Figure to the left shows headlamp aiming pattern for driving
    on right side of road; for driving on left side of road, aiming
    pattern is reversed.
    c. Dotted lines in illustration show center of headlamp.
    "H-: Horizontal center line of headlamps
    'WL": Distance between each headlamp center
    "L": 5,000 mm (196.85 in)
    "C"- . 50 mm (1.97 in)
  11. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  12. #8
    Yeah or try a car with good lights a set distance from a wall then adjust yours to the same height from the same distance maybe .
  13. #9
    Aug 2011
    North West Tas
    56 Post(s)
    But THIS POST IS WORTHLESS WITHOUT PICS~!! lol
    My brother is on his way over, he's a mechanic, ill see what he suggests.....
  14. #10
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by 97_gq_lwb View Post
    Thats a good idea. But i suppose the other car would have to be the same height etc...??
