30th September 2011, 10:46 PM
Rust
Hi everyone, i ran into a bloke he said to me ive got a GU as well and its rusty under the rubber that sits on the cabin side of the rear barn doors, so while he was there i opened my rear barn doors peeled off the rubber closest to the roof of the car and i was shocked rusty, F__-en thing its only 9 year old and rusty, he tells me his is 5 yrs old and needs to weld in new rubber lip.
Advice to all check under that rubber before its to late.
I will be busy now sanding grinding painting.
The Following 2 Users Say Thank You to suvrd28 For This Useful Post:
AB (30th September 2011), patch697 (1st October 2011)
30th September 2011 10:46 PM
30th September 2011, 11:41 PM
I would also check your radiator support panel.
That's where mine is rusting.
25th March 2012, 09:07 PM
Old post I know
Yep both common spots, Mine has rust in both spots. I didnt bother doing anthing yet. Will do the radaitor support panel some stage.
31st March 2012, 09:26 PM
i spray some fish oil under the rubber in every 6 months. so far no rust.
where is the radiator support panel? on the side of the radiator? can you view it from the front or from the bottom?
31st March 2012, 11:40 PM
Radiaitor support panel goes right across the front. The rust is normally at the bottom. It is near the rubber body mounts.
5th April 2012, 12:31 PM
Old MK Pat rusted out here to.
looks like a inherent problem.
fish oil did stop it, when applied every 4-6 mths.
5th April 2012, 01:12 PM
Is the radiator support panel the cross member?
SPEED METAL NEVER WENT AWAY>>>>> ONLY OUR HEARING DID!!!
8th April 2012, 07:16 PM
The radiator support panel is actually the whole panel which your bonnet shuts on, holds your radiator, headlights and the tie bar (the section that has the 2 front body mounts on it) which is probably the bit your calling the cross member.
Cheers Mick.
