Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: RE4R03A / RE4R01A Auto Transmission Manual
    Apr 2017
    Russia, Kamchatka region
    Thanks, but I think maybe it solenoid?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    @AB, this still needs sorting for him mate
    Hi mate, just checked your account, you never clicked on the email confirmation when you joined the forum so your still pending which means you can't download. Only @AB can sort this out for you.
    @AB can you change his settings please
    Toddie
  4. #13
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Quote Originally Posted by Fear75s View Post
    A faulty solenoid should show in the fault codes. The resistances of all the solenoids can be check from the TCU plug if you can get a copy of the TCU pinouts.
    Could also be a sticky piston in the valve body if the servicing hasn't been regular.
    John
  5. #14
    Apr 2017
    I think about it to. The other day, in the presence of time I'm going to change valve body. If the problem is not in it, I'll change gearbox. How will I do this, I'll write what was the matter. The benefit is a spare gearbox in stock and 1 more for spare parts. Thank you))
  6. #15
    Morayfield, QLD
    If you can get a 2nd valve body, it will more than likely have the solenoids still attached so you could check them first before installing. I would also dismantle and clean the valve body before fitting, it's not hard to do.
    Do you have a workshop manual for the RE4R03A?
    John
  7. #16
    Apr 2017
    I haven't workshop manual
  8. #17
    Morayfield, QLD
    Send me an email address by private message and I'll send you a copy.
    John
  9. #18
    Aug 2010
    17 Post(s)
    Hi John, do you have an electronic version of the workshop manual?
  10. #19
    Morayfield, QLD
    Todd, I've got the AT.PDF. I just sent a copy to our Russian friend.
    John
  11. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    Fear75s (23rd July 2017), NissanGQ4.2 (13th July 2017)
  12. #20
    Mar 2020
    Thanks for the useful information
