21st March 2012, 07:38 PM
Automatic Temperture Sender
Hi All,
Did a quick search and couldnt find too much.
Has anyone got a picture or two for the install of the sender for Auto Temp?
I am thinking that you put some elbow joiner at the inlet to the radiator from the Trans.
I dont want to drill holes etc.
OBJ
21st March 2012 07:38 PM
21st March 2012, 07:53 PM
Rotaredom
Hi mate, are you looking at installing an aftermarket sender?
21st March 2012, 07:58 PM
Hi mate. The auto has two temp senders fitted to the valvebody inside the pan. Are you talking about fitting an extra external sender and gauge? If so, wholesale automatics do a kit ( a bit too much $ for me). They remove a bolt and tap a thread into it then fit the sender to that and run the gauge into the cab. Not sure which bolt they use sorry. Not sure if there's other ways of doing it but I would think that wholesale automatics would choose the best way as they do quality work.
Sorry no pics, and hardly any info....lol
tappa slappn about
Hello from Under Down Under!
22nd March 2012, 01:02 AM
Hi All,
Yes I would like to fit a temp gauge for the auto. I have seen the Wholesale automatic ones and would like to do something similar. They bolt into the Radaitor I think.
I want to use the new VDO 52mm Digital temp gauge.
25th April 2012, 03:43 PM
Hey mate,
Just wondering if you had much luck with doing that?I have a 4.8 and would like to put a temp guage on the auto just for piece of mind!??
26th April 2012, 07:29 PM
No luck yet, the wholesale automatics one is analogue, I have a digital VDO 52mm gauge, I have both a sender and the gauge. Just would like to fit it some how.
26th April 2012, 08:00 PM
Rotaredom
Did you read this: http://www.automatictransmission.com...p?NewsId=42067
This is the only way to set it up, even if you use your gauge and sender you will need to get something made up for the sender to go into the transmission's cooler union.
You could do it other ways, but this would be the best method.
Todd
26th April 2012, 10:24 PM
#8
are you going to fit a aftermarket trans cooler? i fitted the largest pwr cooler, i think it was made for 8cylinder cars and mine won’t get above 95deg/c in sand with 33s and averages 80deg Celsius i cant rember how much the cooler was as i fitted it nearly 3 yr ago.
fit a cooler and you may not need a gauge.
28th April 2012, 09:55 AM
#9
hi i installed the wholesale auto temp kit other day it was really easy with there set up, u just replace the bolt that holds the oil pipe onto the trany its on the drivers side at the front of trans (this is the outlet to the cooler where the oil is at its hottest) at the moment i have not towed with it on but my temps are about 55-65 around town and short trips on hwy.
28th April 2012, 11:47 AM
#10
fishnsurf
Hey mate, if you don't mind me along, what did this cost you?
Teno's Troll...
08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
