11th September 2011, 12:06 AM
diff ratio question
Hi friends just wondering if the diff ratios in the mq/mk patrols vary between the petrol and diesel models, and if so what are the ratios?
Regards,
BIGARCH
11th September 2011 12:06 AM
11th September 2011, 02:28 AM
mines a turbo diesel and I have 4.3s
From what I have been reseaeching petrols are 4.6 and some diesels are 4.1.
Your ratio will be on a tin plate, on the drivers side inner guard right up the front.
mine says HG43 meaning the diff type and 4.3 ratio
11th September 2011, 11:49 AM
cool, thanks for your help Nemo.
11th September 2011, 07:25 PM
no worries, I just picked up a diff out of a turbo diesel today and it is a 4.6 ratio.
could of had different diffs fitted thou, hard to say as it was just a chassis with the diffs but the guy wrecking it said it was a turbo diesel.
11th September 2011, 09:25 PM
My book only covers MQ diffs sorry
Tim
13th September 2011, 01:43 AM
Finly Owner
Tim
that's ok mate, wont take long to pop the centres out and count the teeth
thinking of swapping all the suspension, steering parts and both diffs out of my spare parts bus as all my ball joints are rooted, wheel bearings screwed, leafs out of wack etc etc
13th September 2011, 11:02 AM
MQ l28/sd33 = 4.625
P40 (4 litre petrol) = 4.11
MK 4.33
MK ute (H260 diff) = 4.88
Theyre all interchangeable , EXCEPT the H260 rear diff
14th September 2011, 12:12 AM
#8
No need to count teeth, the info is on the out side edge of the crown wheel.
It will have number like this 35:8 35 crown wheel teeth 8 pinion teeth.
the one I pulled out of my mq has 35:8=4.375 and the one I got from the wreckers has 37:8=4.625
15th September 2011, 05:01 PM
#9
nemo
Just make sure the front and rear ratio are BOTH the SAME
