7th May 2014, 01:33 PM
Catch can install
Hi,
Probably loads of posts on Provent catch can installs, so if i am re-igniting a flame, can you please push me onto the correct link.
I have been reading with great interest the NADS installs and MAF cleaning etc, as I have been struggling with loss of power about 1 hour into my journey without towing and on a relatively easy drive. With all the reading, and it really sounds like a dirty MAF issue - pretty sure it has not been cleaned by our Mechanic - might just be ignorance. I now have the MAF cleaner from CRC (as recommended by YNOT some months back), and will be doing it this weekend.
I presume that oil is part of the issue of dirty MAF, and if so then it makes sense to start planning the next step - Oil Catch Can. The questions i have on this what temps run through the oil pipes, just want to ensure i get the correct hose. I mean you could splash out for st/st braided hose, or normal rubber at less than half the price -what should i be concentrating on and what about distance from Turbo - does this make a difference.
My Patrol is 3.0Di diesel, stock standard.
Looking forward to getting stuck in to my truck..............
7th May 2014 01:33 PM
7th May 2014, 03:41 PM
Hardcore
Hi Beucam,
Check out this link and is you need catch-can contact Mudski, he's a vendor on here and will see you right.
http://www.nissanpatrol.com.au/forum...=catch+install
Will be lots of other posts on here re the install, try searching 'catch can install' in the search bar.
Jack
7th May 2014, 05:24 PM
If using the Provent can some are using flared XA Ford heater hose instead of stepping up hose sizes,
looks neater IMO
Smoothrun (6th January 2018)
7th May 2014, 06:32 PM
Yep what TD said, use the falcon hoses, but remember they will perish quicker since they are not rated for oil. Here is a picture of mine. Both hoses cost me $16 from repco and are a perfect fit on both ends. My other setup with hoses and hose size reducers looked very messy so I ripped the can out to fit these hoses.
Attachment 44251
Here is the before picture with the reducers.
Attachment 44252
The Following 5 Users Say Thank You to Hodge For This Useful Post:
Bigcol (25th December 2017), elshago69 (23rd January 2015), Meson (24th December 2017), Semmo (22nd October 2014), Smoothrun (6th January 2018)
22nd October 2014, 07:57 AM
Great setup thanks for sharing.
3rd November 2017, 12:50 AM
now I understand the catch can a bit better now.
24th December 2017, 08:25 PM
