15th August 2010, 12:03 PM
TB42 Tappet Adjustment
This is a widely ask question by many DIYers so I've set it out in point form so whom ever needs it may copy & print it out for future use.
TB42 Tappet adjustment.
Adjusting Intake and Exhaust Valve Clearance
Adjustment should be made while engine is warm but not running
1. Set No. 1 cylinder at top dead centre on its compression stroke,(with timing marks aligned remove distributor cap the rotor button should be pointing at number 1 ignition lead position in reference to the distributor cap if its not rotate engine 360 degrease) and adjust valve clearances 1,2,3,6,7,10
2. Set No. 6 cylinder at top dead centre on its compression stroke, (with timing marks aligned remove distributor cap the rotor button should be pointing at number 6 ignition lead position in reference to the distributor cap if its not rotate engine 360 degrease) and adjust valve clearances 4,5,8,9,11,12
Valve clearance
Intake 1,3,5,7,9,11 - 0.38mm (0.015 in)
Exhaust 2,4,6,8,10,12 - 0.38mm (0.015 in)
Adjusting screw lock nuts - 16 - 22 Nm (1.6 - 2.2 kg/m, 12 - 16 ft/lb)
If you are running duel fuel it is a good idea to set your tappets 1 to 2 thou bigger in gap as LPG has a tendency to close up the gap.
Although this is a widely used practice its not an absolute necessity.
Paul
The Following 15 Users Say Thank You to patch697 For This Useful Post:
bigazz (19th March 2011), Brianwanless (27th December 2017), Chubba (1st September 2015), crouchy1989 (14th March 2013), dattodanil (17th June 2012), Finly Owner (11th September 2010), fukitol72 (22nd March 2015), my third 256 (13th November 2013), Petrolling (13th May 2014), Ruby (3rd April 2011), Russell1974 (13th September 2010), RustyR (14th September 2011), sacratone (9th February 2017), swerver (12th March 2015), YNOT (13th September 2010)
15th August 2010 12:03 PM
15th August 2010, 03:38 PM
Administrator
15th August 2010, 06:38 PM
The proceedure for TD42 is exactly the same, but you wont be able to check the rotar button postion to confirm whether it's 1 or 6 on TDC. Easy way to tell is set crank to TDC by timing marks, if both rockers on No. 1 are rocking then No. 1 is on TDC. Like wise No. 6. I'm not sure of valve clearance for TD42 but from memory I think it's .0014 in.
Tony
The Following 2 Users Say Thank You to YNOT For This Useful Post:
1tuffgq (18th February 2011), Brianwanless (27th December 2017)
15th August 2010, 08:58 PM
and 3.3 turbo whats the go there please guys?
10th September 2010, 10:45 PM
patch697
Valve clearance
Paul
another one for the file as it can be for any thing that needs index
13th September 2010, 01:07 AM
Thanks paul very handy to have as I will be doing this soon cheers
13th September 2010, 01:09 AM
Russell1974
What you running Russ TB or TD?
13th September 2010, 01:51 AM
#8
patch697
I have the 4.2 turbo diesel
15th September 2010, 07:04 PM
#9
Hi everyone,
That is a very good write-up on tappet adjustments Paul, very specific. I particularly liked the mention of visually looking at the rotor to indicate TDC firing. I did not use that method in my writings. I would like to offer another view if I may. I have written an article myself on my website which explains three methods of adjusting tappets that is tranferrable to almost any engine. Hopefully this link www.tuning.mbs.id.au/TechTalk/TT2.htm will take you directly to the article without going through my site, but if it doesn't please go to www.tuning.mbs.id.au Click on the Tech Talk menu on the left & then click on the TT2 button. Hope it is useful to you.
Chhers
Mike
The Following 5 Users Say Thank You to oldtimer For This Useful Post:
1tuffgq (18th February 2011), patch697 (15th September 2010), sacratone (9th February 2017), swerver (12th March 2015), timbar (18th May 2011)
10th February 2011, 05:47 AM
#10
Someone will tell me where to find cheap valves and valve lifters? I did the disassembly and are nearly all destroyed ....
